346CI + tt + 6spd= ???
Old Jan 19, 2006 | 03:59 PM
JAXX's Avatar
JAXX
Default 346CI + tt + 6spd= ???
Looks like I am getting closer to getting my car up and running. Had to find a way to keep up with all these supercharged vettes running around town. Any way, Does any body want to quess what the final numbers might be? I say mybe 14 or 15 pounds of boost!
A & A forged short block 8.8 to 1 comp.
AFR 205 Heads!
Small Blower cam (224 x 228)
ECS fuel system with motron 60 lb inj!
HP TT kit with 57mm turbos
99 FRC 6spd
JAXX
Old Jan 19, 2006 | 04:06 PM
DDSLT5's Avatar
DDSLT5
Feels like 700-800 rwhp!
Old Jan 19, 2006 | 04:07 PM
Z06VET's Avatar
Z06VET
My guess is 685 rwhp . Do we win a prize for whomever is the closest ?
Dan
Old Jan 19, 2006 | 04:10 PM
JAXX's Avatar
JAXX
Dan
You might but it has to be to the XXX.XXX rwhp. close dont count
No, Just for fun
JAXX
Old Jan 19, 2006 | 04:15 PM
rplaster's Avatar
rplaster
I'm going to say 850 with 14#'s of boost.
Old Jan 19, 2006 | 04:35 PM
OneBadCEZo6's Avatar
OneBadCEZo6
I'll say 800-900 With 15psi.... I think the 205 Heads will slow the car down.. Might have been better with the 225 heads that flow 340-350cfm..
Good luck steve
Old Jan 19, 2006 | 04:38 PM
mdhmi's Avatar
mdhmi
Mark
Old Jan 19, 2006 | 04:48 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
720rwhp.
Old Jan 19, 2006 | 05:33 PM
JAXX's Avatar
JAXX
I would be happywith some of the #'s posted!
JAXX
Old Jan 19, 2006 | 05:41 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
I would say between 650 rwhp to 710 rwhp
Old Jan 19, 2006 | 07:28 PM
Tenderfoot's Avatar
Tenderfoot
You should get pretty stout numbers with the HP kit at 15 lbs of boost. I'm guessing 750-800RWHP.
Old Jan 19, 2006 | 08:38 PM
Chris.Shea's Avatar
Chris.Shea
do you have the full kit yet? pm me back too..
Old Jan 19, 2006 | 09:36 PM
Yano's Avatar
Yano
AFR 205 Heads!
99 FRC 6spd
JAXX
I am going to guess 45RWHP, with that cam you are going to blow your boost out the exhaust
Old Jan 20, 2006 | 12:33 AM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
That's what I thinking. Who choose the cam?
Old Jan 20, 2006 | 01:12 AM
mdhmi's Avatar
mdhmi
Why would you pick a blower cam for a turbo setup? A good turbo cam will have a much different profile than a blower cam.
Mark
Old Jan 20, 2006 | 06:20 AM
JAXX's Avatar
JAXX
Mark
I bought my short block from A & A and Andy recommended that cam. I say Blower cam in a general sense. This is not a good turbo grind? 224 x 228 .585ish lift (about) 115lsa
JAXX
Old Jan 20, 2006 | 06:21 AM
rplaster's Avatar
rplaster
Mark
Why would it be such a diferent profile? Blower or turbo the air is being forced in. Just did a search on turbo cams and it looks like there are alot of variables in picking the right cam. Even some of the guys on here that know alot seem to be unsure about it.
To 346CI + tt + 6spd= ???
Old Jan 20, 2006 | 12:24 PM
Yano's Avatar
Yano
I was told on the turbo you want some back pressure to help spool the turbos on the SC you want the exhaust gases out ASAP so you want the 228/236 type of range.
On turbo cams you almost want the reverse set up.
Talke to ROAD REBEL or LPE
Old Jan 20, 2006 | 02:23 PM
#001 2001 Z06
As Yano, Mdhmi and I have stated. Cams are completely different for blowers and turbos.
Old Jan 20, 2006 | 02:29 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
probably more hp than your tires can handle.
mightymouse on ls1tech made a little over 900 with a single turbo on a 364 iron block with a 6 speed. in his heavy weight firebird, it went almost 150 mph in the 1/4 on 27 inch hoosiers.
talked to him today and hes got a ls2 in it now and said it will probably make 1000 at the wheels on race gas.
good luck, your in for a wild ride!
