HELP....stupid question.
Old Feb 2, 2006 | 09:19 PM
NXTFAZE's Avatar
NXTFAZE
Default HELP....stupid question.
Friend of mine has a 402 stroker built and it made 517 rwhp and 465 tq down south at 4 to 5 thousand ft above sea level.
Got it to a dyno today here in NC and it made considerable less hp.... 489/442 running really lean up top so we couldn't spray the 150 shot.
My question is simple... how much hp can the stock injectors support NA?
I thought the stock injectors were good up to 500 rwhp and am wondering how the builder/ tuner of the 402 got 517 rwhp????? Not sure wether to call or maybe the higher altitude helped the stock injectors....
His car was running real lean from the mail order tune that he got from the motor builder. His initial tune was very rich while he was breaking in the motor. Just trying to figure out how to get him back up to his original numbers......
Thanks guys....
Old Feb 2, 2006 | 09:30 PM
TaTommy888's Avatar
TaTommy888
517 rwhp and 465 tq on stock injectors!!!
I would say they MUST have been upgraded....
My 72lbs injectors hit 75% duty cycle on my turboed LS6 making about the same power!!!
Tommy
Old Feb 2, 2006 | 09:36 PM
NXTFAZE's Avatar
NXTFAZE
NA hp is different than FI hp (from what i have heard)..... I made just over 500 rwhp w/ my h/c procharger and needed larger injectors.....
Anyone else?
Old Feb 2, 2006 | 09:52 PM
BlackMagicC5's Avatar
BlackMagicC5
Thats odd, I'm pretty sure most tuners recommend upgrading injectors with just a simple head/cam swap. I could be wrong though.
DDSLT5's Avatar
DDSLT5
Anyone else?
hp is hp. fuel is fuel. The stock injectors can only deliver so much of it, N/A or no.
Old Feb 3, 2006 | 12:06 AM
NXTFAZE's Avatar
NXTFAZE
Old Feb 3, 2006 | 12:08 AM
QuickSilver2002's Avatar
QuickSilver2002
Not true. The BSFC (Brake specific fuel consumption) is much higher on FI engines. The reasons for this are pretty obvious if you think about it, unless you can come up with that "free power" fi system (it would have to be driven externally).
As an example
27lb injectors will get you to 500 na rwhp. Under FI, you would need 37lb.
Here is a worksheet with some formulas you can usehttp://www.rceng.com/technical.htm
One more thing, the heat of the fuel can have a big impact on the fuel pressure and the pump. I would start with the pump and worry about the injectors if the duty cycle goes to high.
I don't know what blows up more FI ls1s, hot fuel related pressure issues or oil from an improperly setup PCV.
Old Feb 4, 2006 | 12:18 AM
Skunkworks's Avatar
Skunkworks
As an example
Old Feb 5, 2006 | 09:07 PM
DDSLT5's Avatar
DDSLT5
As an example
Hm. Interesting.
Old Feb 6, 2006 | 08:11 AM
TaTommy888's Avatar
TaTommy888
That is great information regarding an FI engine's increased fuel needs, BUT I still can't believe that his engine, producing about 600hp (517 at the wheels), is able to run at WOT with stock injectors.
I would have thought stock injectors would go static way before the 600hp mark!
Learn something new everyday I guess
Tommy
To HELP....stupid question.
