Head Gaskets ?
Old Feb 13, 2006 | 03:35 PM
Slovette2000's Avatar
Slovette2000
Default Head Gaskets ?
What would happen if a shop put 6.0L head gaskets instead of the 5.7L gaskets that should be on the car?
Old Feb 13, 2006 | 04:02 PM
mdhmi's Avatar
mdhmi
Are you using 6L heads on a 5.7L LS1 motor?
Mark
Old Feb 13, 2006 | 04:04 PM
DDSLT5's Avatar
DDSLT5
Hmmmmmmm. Aren't they the same bore?
Slovette2000
Mark
5.7L heads and they put 6.0L head gaskets
Old Feb 13, 2006 | 06:08 PM
denscor's Avatar
denscor
I think the headgaskets are different! Different part numbers pretty sure. I would say coolant leaking into cylinder loss of compression and oil in cylinders. Thats just my guess.
Old Feb 13, 2006 | 08:15 PM
auctiondepot's Avatar
auctiondepot
Head Gaskets are specified by bore and compressed thickness.
Stock 5.7 LS1 is 3.91" by .054" thickness.
When the gasket is larger than bore you will have a lower compression because of the increased volume from the gasket, about a tenth at most. Bore 4.00 - 4.135"
It is improper to refer to a 6.0L gasket as this does not tell what gasket is used.
As long as they are for an LS1 / LS6 / LS2, leaks are not an issue with the proper torque.
To Head Gaskets ?
