LQ9 heads with Boost
Old Feb 14, 2006 | 06:35 PM
CL's Avatar
CL
Default LQ9 heads with Boost
Anyone running stock 6.0L heads 72cc or the Patriot Performance GM LQ9 6.0L Stage III Heads on FI car. What boost level have you been able to run safely with a stock bottom end. I am dealing with a stock C5 with a Twin Trubo STS kit. I thought I would get some options before I just order a set of Patriot III heads and started turning up the boost to 8-10psi.
Old Feb 14, 2006 | 07:07 PM
AVB's Avatar
AVB
My buddy's got the PP heads on a TTi Stage1... seein about 9.5:1. Don't know about safe but w/ alky it see's 12psi everytime it get's out.
Arnel
Old Feb 15, 2006 | 12:29 AM
Skunkworks's Avatar
Skunkworks
Others have pushed similar boost with similar combo, with good results. Tune is the key.
Mike
Old Feb 15, 2006 | 06:34 AM
CL's Avatar
CL
Thanks for your comments
Old Feb 15, 2006 | 07:50 AM
racerrob333's Avatar
racerrob333
I had them on my car made good hp but I was having a lifting problem the deck is to thin so I put a set of afr heads problem solved. When I had the patriots on their and only 7 lbs of boost never had a problem but do yourself favor cause you will allways want more so get the afr heads they can hold alot more boost
To LQ9 heads with Boost
