? Line lock for FI
call cartek, forum sponsor.
they have kits with prebent tubing ready to install.
its not listed on thier website but if you call and ask for dave he'll hook you up..
BTW: line lock for FI..???? tossed me for a loop...nothing to do with FI..comes in handy for anybody....even my kids v6 camaro has one...
just FYI
just FYI
I think I recall ordering the handle from Jegs for around $30 and then had a local machine shop drill/tap it to fit with the Hurst short throw shifter.
The line lock is also from Hurst and is around $125.
The pic isn't the greatest, but it should give you an idea. Mine looks pretty much the same, but doesn't display the Hurst logo on it.
Mark
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by sprayedc5
Cartek here as well, 30 min install if that..
I bent my own lines... and tired using an adapter for the metic fitting on the ABS block. I ended up breaking a fitting off down inside my ABS block (since the adapter would not seat properly). Luckily, I was able to get a machine shop to get it out for me. I then had to machine another adapter to make it fit.
Whatever you do, buy a kit. The fittings are very odd and awkward. Each year is a bit different. I think they actually had metric on one end and sae on the other
I was looking for this as well did a search and asked a while back with no luck
