Proper PCV Setup
Old Mar 1, 2006 | 08:59 AM
mwbmd11's Avatar
mwbmd11
Default Proper PCV Setup
I've seen in a couple of threads the mention of inadequate PCV setup causing engine failure on FI motors. What is considered a proper setup. I have the line that went to the intake going to the air filter.
Old Mar 1, 2006 | 10:04 AM
xlr8shn's Avatar
xlr8shn
Posted elsewhere, do a search here @ CF for "McMaster"...
http://www.mcmaster.com/
search for "7775 K52" on mcmaster's site. ~ $12.16 plus shipping. Then add a couple of brass barbs to it.
Place the check valve inline with your pcv system (and between your catch can if you have one.) Make sure the valve is oriented so that boost from the intake cannot be forced into the valve covers.
Old Mar 1, 2006 | 10:58 AM
usd2sing's Avatar
usd2sing
same here... curious(sp?)
Old Mar 1, 2006 | 11:14 AM
QuickSilver2002's Avatar
QuickSilver2002
There is more to it than a check valve. It basically needs to also vent under boost.
There have been a ton of threads on it and I have spent time creating detailed diagrams, taking pictures..., but the forum search feature sucks so bad that I can't find any of them.
This site is run very poorly from a search persepctive. You sponsers need to get on them.
Old Mar 1, 2006 | 11:30 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Or get the mods to sticky some of the common questions like this. It comes up every few weeks or so.
Old Mar 1, 2006 | 11:46 AM
Villain C5's Avatar
Villain C5
this is something I've been trying to get good info on but cant find much through a search
Old Mar 1, 2006 | 12:00 PM
mdhmi's Avatar
mdhmi
There ya go:
http://forums.corvetteforum.com/show...cv&forum_id=86
Mark
Old Mar 1, 2006 | 12:07 PM
usd2sing's Avatar
usd2sing
Originally Posted by mdhmi
very nice
thanks
Old Mar 1, 2006 | 12:27 PM
bernrex's Avatar
bernrex
I've looked over the thread mdhmi linked us to.
Looks like this would be needed only if we boost above say 8 lbs....
Do I infer correctly about critical pressure @ 8 or above ?
Old Mar 1, 2006 | 12:39 PM
usd2sing's Avatar
usd2sing
im running a maggy, 6.5-7lbs, and have seen many comments on the forum about pcv improvements...so i found the link to be helpful.
Old Mar 1, 2006 | 12:44 PM
QuickSilver2002
It is a potential problem with just about any boost level, but the issue becomes more serious as boost and blowby increase.
I've seen it be a major issue at 8psi.
Old Mar 1, 2006 | 12:48 PM
Brian@FI Performance's Avatar
0Brian@FI Performance
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
I should have the basic kit ready to ship on Monday.
Brian
Old Mar 1, 2006 | 05:02 PM
denscor's Avatar
denscor
What are the kits going to cost? And how soon will they be ready?
Old Mar 1, 2006 | 05:26 PM
Former Vendor
Not sure on the money yet, should have 5 ready to ship on monday.
Brian
Old Mar 1, 2006 | 06:57 PM
hpcubed's Avatar
hpcubed
Quicksilver,
If I remember correctly you have that trick little K&N filter on your valve cover port. If so were did you get it. I'm not refering to a breather on the oil fill cap.
Old Mar 1, 2006 | 07:17 PM
denscor's Avatar
denscor
Are all of the kits sold? I need a kit!
Old Mar 1, 2006 | 08:13 PM
ProtoVette's Avatar
ProtoVette
QuickSilver2002,
I saw your diagram of the system you made.
What kind of restrictor valve do you use for your fresh air intake into the crankcase?
Thank you,
Chris
To Proper PCV Setup
Old Mar 1, 2006 | 11:16 PM
king_pin's Avatar
king_pin
St. Jude Contributor
Originally Posted by hpcubed
Quicksilver,
I have a extra one PM If you want to buy it $25 shipped its new in package.
Kevin
Old Mar 13, 2006 | 01:12 AM
vertC6's Avatar
vertC6
From my research this is the best way to vent the pressure, I know this is a diagram for a 3000gt, but it is the same principle. Run the small one way Krank vent from the PCV to the manifold, and the larger KV tie in both valve covers to the KV and then to a catch can. It will allow pressure out under boost, and keep vaccum in during normal driving.
http://www.stealth316.com/2-krankvents.htm
Old Mar 13, 2006 | 03:50 AM
FlyinNOE's Avatar
FlyinNOE
Brian
I'm waitin'. PM me!
Brian
