Tapping Oil Pan
How thick is the wall of the oil pan? and how many threads are you able to cut? Does the 3/8" connection feel snug? or has anyone had any problems. It doesn't seem like the pan is wide enough to allow that many threads.
Link in sig
http://spaces.msn.com/motormaniac/photos/?_c02_owner=1
Roger
I supply a "Roto Broach" to cut the pan. This is very much like a small hole saw. It cuts a small circle rather than drills a hole. If you're very careful you can stop just before the saw cuts through the back side of the pan. The small piece of aluminum that's left in the middle of the circle can be pulled out with a small pick. You don't get a bunch of shavings in the pan.
Pack some grease in the tap and keep pulling it out every couple of turns to clean it off, and you won't get much in the pan from the tap either.
Then I get a bent Q Tip with some grease on it and dab around inside the pan to pick up any small chips that may have gone astray.
Remember that the pickup screen in the pan has a very fine mesh and won't allow anything that would hurt the motor through anyway.
If you're still scared after all this, I can supply you with a dipstick tube that has a drain welded into it. No drilling is required at all with this setup. The pan drain is recommended as it is 1/2" as opposed to 3/8" and drains better.
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
ANDY GREEN- OWNER/ CEO -A&A CORVETTE / A&A SUPERCHARGERS
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
I just tapped both sides in 45 minutes using the 9/16" rotabroach and a 3/8 NTP Tap and here's the sequence. Just one hint for drilling. Center punch the spot you want to drill. Lube up a 1/8" drill bit and drill a pilot hole. Then stick the rotabroach pin in the hole and start cutting. When you break through, the plug will(should) stay on the pin as mine did. Here's the end result with the plug on the right (the pan is 0.21" thick).
A perfect hole with a 3/8" drill. Notice, all the shavings and chips are outside where they belong.
The 9/16" bit is a hair bit smaller than the 37/64" bit called for but the pan is soft Aluminum and easily taps as it should with a socket wrench.
The finished product
I hope this help those of you who need to do this still.
IQ
