I'll be installing one on my C5R 427 with LS7 heads in the next 30 days. It will be interesting to see how much boost it can produce at reasonable compressor speed with these 370 cfm+ heads. I'll post results as soon as we have numbers.
I have had one on a 408 with a single intercooler and it will make damn near as much boost as you want it to. I have seen 22lbs before the restrictor plate it made over 800rwhp on 15lbs on pump gas Its a noisy SOB though
I believe I saw a vid of your car racing a red and white GTS, how much power were you making then?
I am curious about those of you who are running ProCharger F1R head units. I would like some information on your set-up such as:
- motor displacement (c.i.)
- cam specs
- heads
- auto or manual
- intercooler set-up (twins or FMIC)
- compression ratio
- boost (psi)
- hp
- tq
Much appreciated...
LS12NV
408 ci comp cam have to check on it to see. 317 heads maxed out with 2.10 intake 1.60 exuast manual trans, fmic 8.5:1 comp. meth not to dyno yet switched from 4.5' pulley to 4' car awaits paint then tune I dont know who to take it to for the tune to actually get it tuned and not just someone elses file downloaded
What is the price difference between a D1 and a F1. Also what are the benifits of a F1 over a D1. I think 800-900 could be made on a D1 and if a F1 is more money then why would someone go with a F1.
