Gauges for Supercharged C5
Former Vendor
From: FI Performance : Norwalk Connecticut www.FIPERFORMANCE.com
I can get you into wideband air/fuel, boost and fuel pressure in a dual pod.
Wideband $369
Boost/Fuel $299
Pod $65
plus some shipping.
I have hooked many c5 guys with this package and they are very happy.
Wideband $369
Boost/Fuel $299
Pod $65
plus some shipping.
Wideband $369
Boost/Fuel $299
Pod $65
plus some shipping.
Wideband $369
Boost/Fuel $299
Pod $65
plus some shipping.
Former Vendor
Originally Posted by 2004SpiralGrey
do u need a fuel pressure gauge or can i go with boost/vac and air/fuel only
Brian
Originally Posted by mdhmi
I went with boost and fuel gauges on the a-pillar. For the most part the gauges are just for looks - they're much too difficult to pay attention to at WOT.
Mark
Mark
Of course i don't have the power either that you do
But, i do have the same guages
Wideband $369
Boost/Fuel $299
Pod $65
plus some shipping.
Wideband $369
Boost/Fuel $299
Pod $65
plus some shipping.
a good guage i used to run in my rx7 was an egt gauge. if you get a dyno tune you can figure out what temp the exhaust gas is at when you're running the correct a/f ratio. you really need the tune because the temp will vary from installation to installation based on where you put the temp sensor
Originally Posted by mikes99corvette
Im running Autometer Boost and Fuel Pressure Gauge.........The Fuel Pressure Gauge is Electric.
You would be best suited to have both and the wideband a/f. You would notice fuel issues via the a/f gauge but by then, it could be to late if you notice it going lean to late. When you see your fule ressure drop, you will know right away because with the Spa gauges you can set warning lights.
Brian
Brian
Looks like a pretty neat setup there bud! i like it!
04' SpiralGrey: if u don't go for Brians setup, i would suggest just boost and fuel pressure. Autometer a/f guages are not going to help u worth a darn... they are good for a/f ratio when NOT in boost. they are not accurate at all when in boost...don't wasteur money on it. Boost and Fuel are most important. that is what i use on my blown burban.
If Brians setup uses a wideband version of the a/f, i would use his since u can also use boost and fuel pressure. those three guages are vital in a FI application.
Aj
