200mm Throttle Body
Mike
Not a race car. Im actually hoping the setup as a whole scrubs off some low end to make it more driveable. My only concern with the throttle body is it may act more like an off/on switch. If so I will modify the linkage to be progressive.
It still beats trying to do it manual though. Did you program it at the machine, or use a CADCAM?Very nice work. Is that the motor you are putting it on in your avitar? What is that shaft running along the side of the block?
V2XT around 1990-91. It was broken for nearly a year but I got it fixed $$$ so you will probably see more frequent post's from me. I use AutoCAD and SurfCAM. I have an old manual Bridgeport that I got for free but no way am I good enough to do much more than second ops on it.
you do know that the area for 4 50mm tb is just a little larger that 1 90mm and no where near as much as a 200mm
1 90mm @ 1/4*Pi*D*D = 6,358.5 mm square
4 50mm @ 1/4*Pi*D*D = 7,850mm square 23% larger than 90mm
1 200mm @ 1/4*Pi*D*D = 31,400 mm square 300% larger than the 4 50mm's
after you take into account the loss of area due to shafts the 90mm and the 4 50mm's will be a lot closer. If you give me the dia of the shaft I can calc that out for you. if you assume 3mm for shaft and buterfly on the 90mm and the 4 50mm's you come up wwith a loss of 270mm square for the 90mm and 600mm square for the 4 50's giving you
90mm = 6358.5 - 270 = 6088.5mm square
4 50's = 7850 - 600 = 7250 mm square = 19% larger
Just a little light math before lunch
then again they look killer.
More Than Zero
edit mistake in my formulas numbers are right but 1/2*(D squared) does does not equal R squared lol
1 90mm @ 1/2*Pi*D*D = 6,358.5 mm square
4 50mm @ 1/2*Pi*D*D = 7,850mm square 23% larger than 90mm
1 200mm @ 1/2*Pi*D*D = 31,400 mm square 300% larger than the 4 50mm's
after you take into account the loss of area due to shafts the 90mm and the 4 50mm's will be a lot closer (I guess about 10% diff between the two). If you give me the dia of the shaft I can calc that out for you.
More Than Zero
You beet me to it, I was thinking same thing. It will likely look like a 95mm TB.
Mike
Mike
More Than Zero
Even better. No.... I didn't take any of that into account and appreciate the education. Obviously I just added them together without taking total area into consideration. Shafts are 1/4" with .075" deep flats. Plates are .065" thick. Bores are actually 50.5mm exactly. I really should have known this and I apologize for the misleading title. Thanks for the input and correction. I am humbled.
RonO
RonO
the 1/4" = .25"
.25" - .075" + .065 = .24"
.24" > about 6.1 mm
your shafts are blocking about 6.1mm * 50.5mm * 4 = 1,232.2 mm square
the 50.5mm's give you 8008mm squared
- the blades => 8008 - 1232 = 6776mm squared.
the 90mm if it has the same dim's as the 50's for the blades
6.1mm * 90mm = 549mm squared
900mm = 6358.5mm - 549mm = 5809.5
making the 4 50's 16% larger
the stock is 75mm (i think)
so 75mm = 4416mm - 458 = 3958mm squared
the 4 50's would be 71% larger than stock (assuming that I got the dim of the stock one right)
hope this helps with your tuning.
More Than Zero
