Nitrous install
Here you can see the difference in thickness b/w the two:
I actually used a bandsaw to cut the aluminum and handfiled down all the rough edges.
This is the plate installed before I cut the carpet:
There was not enough clearance with the plate resting above the carpet, so I installed it underneath the carpet and cut it to fit.
I did a hack job of cutting the carpet, but I'll improve it later:
Now you see it:
Now you don't:
Here is a wider view that shows that the panel is now flush with the surrounding area:
Everything can be improved, but it is now a stealthier install. I was even able to use the offset mounts and did not have to switch to two of the lower height mounts for the bottle. Next up is a custom plexiglass panel for some of the system switches including a plugin for a handheld trigger for those situations that require a little more control of the nitrous.
Nice kit btw.
