Bottle mounting
Old Mar 24, 2006 | 04:30 PM
Phil97SVT's Avatar
Phil97SVT
Default Bottle mounting
How are you guys mounting your bottles? I've heard some are using gorilla glue ect. What are the best methods to keep this thing secure???
Phil
Old Mar 24, 2006 | 05:23 PM
DougG's Avatar
DougG
Search for " Bottle mounting pix". You'll see my solution. Other searches will provide solutions for both 10 and 15 pound bottles.
Old Mar 24, 2006 | 10:45 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Top pic is Z06 and bottom is coupe. Both use a piece of 3/8 plywood on top mount with just srews into plywood. The bottom mounts can be through bolted in the spare well, or glue plywood there also. Yes, I used Gorrila glue. My new set-up has dual 15lb bottles using the same method, but I used threaded inserts for 1/4-20 button heads this time over screws, but no pics yet.
Robert
Old Mar 25, 2006 | 05:31 PM
z06pdq's Avatar
z06pdq
From: Only in America can you get paid that much money for crying --the state of Texico
< see sig. 10# bottle mounted on plywood covered in carpet.
Old Mar 25, 2006 | 07:31 PM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
Still installing my system. Going to be a two stage with a DynoTune Dry shot (75-100) with a Nitrous Outlet Wet Plate ((50-75).
Here is what I am doing with the bottle.
The Logo on the bottle blanket is being embroidered, that is a paper cutout pictured for reference.
Finally came up with a panel for the two stage. Pull out the ashtray and this fits with no cutting of the dash
More to follow as I progress
Cheers
Beer
Old Mar 25, 2006 | 07:52 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
My 15lb bottle is mounted on an 1/8" by 3" wide flat plate. I use countoured pieces of 1/4" plate to sandwich the well from the bottom. No cracks in the fiberglass or movement of the bottle. But a 15lb bottle does look kinda silly in the rear well
No thats not the final mounting, that was just from the original mockup.
Old Mar 26, 2006 | 12:11 AM
Robert56@RNS
Collections Hold
Here's another 15lb bottle in a buddy's (Chris Stewart) Z06.
Robert
Old Apr 4, 2006 | 03:18 PM
turboed's Avatar
turboed
hey robert could you please be more specific on the picture of the zo6 or maybe more pics?,i want to do my frc similar so i can turn it on by hand,also did you drill through the carpet?
Old Apr 4, 2006 | 11:12 PM
Robert56@RNS
Collections Hold
On the front mount I Gorrilla glued a piece of 3/8 plywood down and screwed to it. On the rear mount, because of it being a 15lb'er, the mount is in tire well, so I was able to thru bolt and get nuts from underneath, I also used a spacer block on rear mount to raise bottle. On a 10 bottle, you could prob do both mounts on one board. I had an electric noid at first, but removed it cause it is so easy to get at by hand. Hope this helps.
Robert
Old Apr 5, 2006 | 01:34 AM
X-ZZ4's Avatar
X-ZZ4
Cruise-In II Veteran
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
Using the factory CD changer mount plus a 1 x 4 underneath the bottle.....
To Bottle mounting
