Nitrous help
Old Apr 8, 2006 | 10:34 AM
2kvert's Avatar
2kvert
Default Nitrous help
I have a TNT kit jetted to a 150 shot. I have a completely stock engine. I've been told I can hit it with that shot from some people and told by others to upgrade the fuel pump first. Will the engine hold it or do I need to do the upgrade? Also, is the fuel pump all I will need to change to make the kit "safe"?
Old Apr 8, 2006 | 10:59 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Your fuel pump should be okay.... You will want to get a fuel pressure guage.... if you fuel pressure drops under 52 on the spray... time to upgrade the pump.
Old Apr 8, 2006 | 12:08 PM
2kvert's Avatar
2kvert
thanks for the info
Old Apr 8, 2006 | 05:27 PM
Airwolf's Avatar
Airwolf
From: ********************* Florida's Space Coast *********************
You did change your plugs to a copper base (cooler rating) and not stay with the stock platinum, right? If not please do, like to a NGK TR6 plug.
Also spraying that much on a stock tune with full timing "may" be playing with fire. I would get the car on a dyno before doing too much spraying.... Just to be safe. Fuel is probably not going to be an issue at 150.
Old Apr 9, 2006 | 09:57 AM
creighton's Avatar
creighton
i was planning on running a 150 shot as well. i tried it out on the dyno friday. on my graph i could see where the fp dropped deactivating the nitrous by the fpss causing a spike down in power until the pump caught up after the initial pressure drop. however, after the pump caught up again it pulled throughout the run which indicates the stock pump can support the shot. i think the problem is the fuel jet is so large on a 150 shot that the pump cannot keep up initially.
Old Apr 9, 2006 | 10:47 AM
402Sam's Avatar
402Sam
This is why on alot of dyno graphs you will see that initial hit of the spray and the a/f will go lean for that split second when the nitrous comes on. It is the fuel soleniod cleaning the fuel rails out and sucking them dry for a sec until the pump catches back up. Its really not a big deal, alot of cars have them unless you have progressive controller to get rid of the initial 150hp hit.
Old Apr 9, 2006 | 01:24 PM
creighton's Avatar
creighton
you're right sprayedc5, i did see a lean spike when the nitrous hit. that's what lead me to the conclusion of the problem. i just didn't gain enough power on the 150 shot to justify it at this time. i picked up 110whp on a 100 shot. for some reason i didn't pick up 150 whp on a 150 shot though.
Old Apr 9, 2006 | 03:17 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
A conversion to regulator and return at the rails will cure the pressure drop at heavy demand. Also, KB bap can help this issue. The best way to get rid of the lean spike and low pressure issues.
Robert
Old Apr 9, 2006 | 05:10 PM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
Brief lean spikes are typical and not caused by fuel pressure problems. I have wide band sensors on my system with data logging and I get a lean spike of about 16-17 to 1 for about 2/10 of a second with every nitrous activation. This is with a direct port fogger system that has an independent fuel tank and pump. The nitrous gas is under high pressure and gets to the cylinders faster than the fuel - that is what causes lean spikes. Lean spikes of very short duration will probably not hurt your motor.
Old Apr 9, 2006 | 06:18 PM
creighton's Avatar
creighton
what do i use as a reference for the boost a pump?
Old Apr 10, 2006 | 08:56 PM
Robert56@RNS
Collections Hold
True, when talking a dedicated or a properly set-up fuel system. However, with stock fuel system ie: return/regulator at tank, the stock system can't keep up under heavy demand and you will have a more drawn out lean spike (empty rails), and possibly lean under your heaviest load (low psi/volume). Most experts say that if lean spike is less than 1-second no problem. Well, imo, that's tunable and many of us have no lean spike at all.
Try lenghting your nitrous line, that'll help the little spike you have.
Robert
To Nitrous help
