Nitrous Plugs
Old Apr 8, 2006 | 01:54 PM
Blow Torch's Avatar
Blow Torch
Default Nitrous Plugs
I've posted on a couple of forums but realy can't seem to get a solid answer.
I have installed a set of Dart heads which require a flat washer plug, and I am running nitrous, (although actually spaying very seldom.) What is a good replacement for my TR6's?
Some are saying the Denso Iridium plugs work great, but I have also heard that they should not be used with Nitrous...Thoughts??
Old Apr 8, 2006 | 02:29 PM
mean lx's Avatar
mean lx
Do those plugs have the tiny platinum or iridium tips? The thing is...any small metal point will heat up more than a flat or smoot curved surface leading to hot spots and preignition. The more cylinder pressure built up in the cylinder (nitrous) the greater the risk of damaging pistons from preignition. James
Old Apr 8, 2006 | 05:22 PM
Airwolf's Avatar
Airwolf
From: ********************* Florida's Space Coast *********************
I use the Denso Iridium with my 175 shot without any trouble. There is also a TR6 Iridium equivalent that my friend uses which he loves and is cheaper then the Denso. You DO NOT want to use Platinum plugs with nitrous, Iridium or copper is fine, and actually my idle improved with the Iridium over the TR6. I gap my Denso IT20 at .042 just to let you know.
To Nitrous Plugs
