crankcase pressure under boost ?
Old Apr 16, 2006 | 12:05 AM
gary buchanan's Avatar
gary buchanan
Default crankcase pressure under boost ?
02 Z at 5.6 lbs. of boost blows oil avery where, i put on a catch can blew oil out of the filter, any cures welcome !!!
Old Apr 16, 2006 | 12:19 AM
AVB's Avatar
AVB
That kind of blowby at 5-6psi of boost is unusual. You need to do a leak-down to confirm (or not) a bad cylinder. As you get past 10psi there'll be blowby which could be considered normal but not at the level you describe and definitely not at your boost levels.
Also, and you may as well check this out first, check your pcv and confirm its working correctly. To isolate just disconect it and plug the intake where it had been connected.
Hope everything turns out to be all good
Arnel
Old Apr 16, 2006 | 01:02 AM
BoostedBlkZ06's Avatar
BoostedBlkZ06
i had a maggie on my car and i got blow by and it resulting in the oil shooting out from my dip stick, and 3 cracked pistons and a cracked #5 cylinder wall.. but that was b/c my motor was whipped already really bad.... lol
Old Apr 16, 2006 | 01:32 AM
QuickSilver2002's Avatar
QuickSilver2002
That does sound like a little too much blowby for that boost level, but it can happen without proper PCV, check valve...
You need a vent to atomosphere. Go do some searches in this section on PCV.
Old Apr 16, 2006 | 06:17 AM
Warp Factor's Avatar
Warp Factor
Have you had the turbos for a while, and it just started doing this, or did this happen as soon as you put the turbos on?
Where is your oil return from the turbos hooked up?
Edit: Oh, and you don't still have the crankcase air supply connected to the throttle body, do you?
Old Apr 16, 2006 | 01:37 PM
AVB's Avatar
AVB
The other thing is to check your breather(s). Make sure they're not saturated w/oil and are still venting properly.
Arnel
Old Apr 16, 2006 | 03:09 PM
gary buchanan
i have had the turbo's one for 3 weeks blow by was not that bad at frist it did blow the dip stick i used tie's to hold it down. then i put on the catch can it got worse. no i don't have the air supply going to t/b. thanks for feedback ill check the filters! p.s keep it comin
Old Apr 16, 2006 | 03:39 PM
vertC6's Avatar
vertC6
Doesn't sound good my friend to have that much blow by at 5.6 psi, I would take quick's advice go with a one way krank vent valve to a vented catch can or to the atmosphere off the valve cover. That will definitely help, but I afraid it is not going to be the long term answer, you may end up having to swap out some pistons.
Old Apr 16, 2006 | 03:43 PM
vertC6's Avatar
vertC6
http://www.et-performance.com/images/turbokit_lg.jpg
http://www.jegs.com/webapp/wcs/store...0475&langId=-1
Old Apr 16, 2006 | 05:24 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
If you have have the stock PCV system intact, without a one-way check valve in-line, you will be pressurizing crankcase.
Charlie
To crankcase pressure under boost ?
