Dissapointed
Old Apr 16, 2006 | 04:00 AM
brandon1566's Avatar
brandon1566
Default Dissapointed
Went to the track here in tulsa tonight seems the best time I could get was a 12:50 @ 119 . I had a 97 c5 with 100 less hp run almost a full second faster than my supercharged z is. The stock clutch usually lets go around 3rd and I have to get out of it and get back on it and it will grab.
the car has 522 hp does anyone with a z that has around this hp have a time?
Old Apr 16, 2006 | 09:13 AM
JerryL's Avatar
JerryL
Cruise-In II Veteran
Cruise-In III Veteran
You don't provide enough information to do an analysis. Your mph of 119 would normally equate to an ET in the 11.5 range. However, the clutch slippage that you describe is definitely slowing you down. Quick ETs are largely dependent on 60 foot times. With good traction you have the horsepower to get into the 10s but that will likely require 60 foot times below 1.7.
Old Apr 16, 2006 | 09:57 AM
lewishou's Avatar
lewishou
What tires are you running? Also what is your setup?
Lewis
Old Apr 16, 2006 | 11:23 AM
crazygn's Avatar
crazygn
maybe the air is better here in mayland but i dont think so lol, i have 431 rwhp and run 11.34@121.55 on street tires with a 1.64 60'
Old Apr 16, 2006 | 04:33 PM
QuickSilver2002's Avatar
QuickSilver2002
No point in even running the car with a clutch that won't hold. You are just wasting your time. Get that fixed and then see what happens.
Old Apr 16, 2006 | 04:52 PM
mdhmi's Avatar
mdhmi
Something is definitely wrong if you're only trapping 119 MPH.
Mark
Old Apr 16, 2006 | 05:26 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Slipping clutches are not going to get you down the 1/4 mile with low ET's....gotta gewt that fixed
Charlie
Old Apr 16, 2006 | 05:27 PM
brandon1566
I have no clue what the 60 foot times are for some reason the track here for midnight drags does not hand out time slips. I am running goodyear eagle f1 supercar tires. First spins 2nd catches and the clutch startes to slip.
I am trying to find someone here in tulsa to do the clutch but I am having trouble. I have been told to go to xtreem performance, or corvette specialties by rudi. Rudi has never returned my phone call, I would rather not drive to Ok city. I was looking at my engine today bc I had oil on the top of the right corvette cover, the pcv hose came off and I had alittle bit of oil leaking. Is that normal?
Old Apr 16, 2006 | 08:15 PM
uniquec5's Avatar
uniquec5
Give cartek a call they have great clutches. over in the tech forum they are trying to get a group package together.
Old Apr 16, 2006 | 09:49 PM
tlaselva's Avatar
tlaselva
Are they?
Buddy of mine went through one in two weeks. . .
Old Apr 16, 2006 | 10:08 PM
Too-Tall's Avatar
Too-Tall
Hang in there........ Corvettes are not the easiest drag cars especially with a stick.... They like to spin tires, wheel hop, and smoke clutches. IRs are not the best drag setup. Couple of suggestions:
1) Get some drag slicks if your really want to make a 10 sec run...this will also put some added stress on your drive train so be careful.
2) Get a GOOD clutch.....Exedy or even the C6 z06
3) Practice your launch.....find the RPM that spins the tires just a little and nail the 60 ft time like other wise repliers have pointed out.
Take your car to a road course.........that is when they really shine!
To Dissapointed
