F1 Question
Old Apr 29, 2006 | 01:54 AM
dwalker011's Avatar
dwalker011
Say I do keep the P1 headunit, will I need to raise that 8.3:1 C/R up to get the most out of it. Can I use a head gasket or am I going to be milling the heads a little? I know theres someone out there that knows.
Old Apr 29, 2006 | 02:16 AM
RoccoSifredi's Avatar
RoccoSifredi
8:3 is to way to low if you have a P1. I dont think you can mill those heads that much. What size chambers have you and what pistons?
Throw a F1R head unit on the car and 8:3 is perfeckt and much more fun! P1 sucks.
Old Apr 29, 2006 | 02:25 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
If you already have the P1 why not just send it back to ATI for an upgraded impeller to make it a D1--it's less than the $2500 you speak of.
Also, If you did buy a D1 @ $2500 you coud also re-sell your P1 to offset ~$1500 of the costs which would bring it down to ~$1000 (comparable to the ATI re-build).
For the low 8.3 cr, either mill the heads or install different pistons. The head gaskets won't make that much of a difference unless they're extremely thick which I doubt.
Old Apr 29, 2006 | 07:01 PM
dwalker011's Avatar
dwalker011
Thats what I was thinking. Its like $1200 to have the P1 upgraded but, if I sell my P1 then it is only like an extra $1000 to buy the whole new headunit with that all important warranty. I was just figuring that with all the people converting over to the new line of blowers, there might be a few D1's or F1's laying around that could be had for less than $2500. Thanks for the input but, no one has really answered my question about the C/R. Is it too low for a D1? Im sure this will be more detonation resistant but, im thinking it should be more around 9.1:1. Id like to hear everyone's .02 cents. Thanks.
Old Apr 30, 2006 | 03:58 AM
Gatzer's Avatar
Gatzer
You'd be fine with an F1R on your 346, especially with your low compression. It's a little too low IMO.
I recently switched from a D1SC to an F1R on my forged 346. 9.0:1 compression. An 8 rib setup from A&A or ECS is a MUST though. The 6 rib pulleys just can't get the job done without the belt slipping.
