ARP Main Studs????
Old May 2, 2006 | 12:02 AM
chriswtx's Avatar
chriswtx
Default ARP Main Studs????
So are ARP main studs needed in a motor making 750rwhp???If they are do you need to get the mains honed when you replace the factory bolts??This will be on a brand new block 2004' with a stock crank and forged rods and pistons, 317 heads and ARP head studs....
I've bought the heads, Diamond pistons and crank. only a few more parts to go..
Old May 2, 2006 | 01:08 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Their absolutely needed... Why go that far then skimp on the main studs.
I wouldnt think it would be necessary, but I'm not a machinest.
What size rod bolts are you using??
