P1SC pulley size ?
Old May 9, 2006 | 04:07 PM
MawneeC5's Avatar
MawneeC5
Default P1SC pulley size ?
Well guys, as some of you know, I've had a hard time getting a head unit. After two seperate deals fell through on head units, I finally have a P1SC sitting on my workbench.
I ended up buying a used mustang GT kit just for the head unit I paid $1900 for the kit, by the time I sell the Bracket, intercooler, injectors, MAF and BOV I"ll come out with a pretty good deal on the head unit
Anyway here is my dilema. When I thought I had a D1sc on the way I ordered a 4.5 pulley, and the head unit came with a 3.1 ( ) on it. I"m looking for about 8# of boost out of it and I think the 4.5 is going to be too big, especially with my mods What size pulley should I get for my goals ?
Noteworthy Mods:
cam 221/221 575/575 112
LT headers
Borla stingers and high flow cats
Going to have 3" intercooler piping and a huge 32x12x3 FMIC
Thanks in advance for any advice.
Old May 9, 2006 | 04:19 PM
SmoothFRC's Avatar
SmoothFRC
I am sure others will chime in, but I think the head unit you purchased is not the correct rotation? (i believe it has to be reversed)
I think you are looking for a 4.1" pulley, i have a 3.85 on mine and it will hit 9-10#'s at 6000 in the winter, about 7-8 in the summer. But you may want to take it up to 6500.
Old May 9, 2006 | 04:40 PM
MawneeC5's Avatar
MawneeC5
The head unit I bought IS reversed. That was what made it so hard to track one down. There are tons of them out there with normal rotation.
Here in florida its summer 10 months of the year, so maybe a 3.85 is what I'm after
Old May 9, 2006 | 05:10 PM
Villain C5's Avatar
Villain C5
You may want to check further because When i was looking for my head unit I almost bought a Mustang version because it is reverse rotation. Forum members instructed me that there are differences between the Corvette and Mustang reverse rotation, if i remeber it had sometime to do with the position of the internal gearing. I never found 100% soild proof either way,because i ended up with a Vette Head unit anyway, but you may want to look into it.
Old May 9, 2006 | 06:08 PM
MawneeC5's Avatar
MawneeC5
Just got off the phone with ATI. There are no differences in the drive ratio, or gear position between kits. The different ratios are different head units i.e. P1sc, D1sc, F1 ect. He assured me that as long as its the correct rotation, all I have to do is clock it and put on my pulley
BTW he also recommended a 4.0 pulley for 8# of boost for my car after he had me explain my mods. Very helpful
Old May 9, 2006 | 07:36 PM
Brabus2's Avatar
Brabus2
Does anyone know what the largest pulley size you can fit on a 6 rib D1SC??
Thanks!
Old May 9, 2006 | 07:54 PM
Gatzer's Avatar
Gatzer
Thanks!
5.00"
Old May 9, 2006 | 08:44 PM
Villain C5's Avatar
Villain C5
Glad it worked out for you
Old May 9, 2006 | 10:14 PM
Brabus2's Avatar
Brabus2
Originally Posted by Gatzer
5.00"
Good stuff
Approx. how much PSI using a 5" pulley on a D1SC?
Thanks!
Old May 9, 2006 | 10:28 PM
vertC6's Avatar
vertC6
A 5" pulley is what I am going to go with, it will put out between 6.5 and 7 psi at its peak on a D-1. A 4.75" 7.5 - 8psi, a 4.5" 8.5 - 9 psi, a 4.38" is 10psi.
Old May 9, 2006 | 11:28 PM
eb02z06's Avatar
eb02z06
St. Jude Donor '08
On a P1SC a 4.10 pulley is what Andy supplies for a regular Vette-for a Z06 they come with a 4.25-because of the added compression. I would say 4.10 is what you want. If it's a reverse rotation from a Stang, like from a mod motor you should be good.
Old May 10, 2006 | 12:17 AM
Brabus2's Avatar
Brabus2
Thanks for that info!
Old May 10, 2006 | 06:13 AM
Gatzer's Avatar
Gatzer
On my '04 Z, stock, it made 8psi @ 6500rpms.
Old Jun 28, 2006 | 03:40 AM
dwalker011's Avatar
dwalker011
What is the next size/sizes down from a 3.85 pulley on a P1 and what boost will they produce? I have a 3.85 and am looking for more boost. If anyone has one PM me. Thanks.
Old Jun 29, 2006 | 09:27 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
I think you need a 4.1 pulley to be around 8Lbs. Are you planning on keeping that cam. If I was you I would get a different cam, I recommend a 115
Old Jun 29, 2006 | 11:08 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Next size smaller pulley is a 3.70 and I would bet you will at 1 1/2 to 2 lbs of extra boost. I run a 3.85 on my DS1C and I see 14 lbs at 6200
To P1SC pulley size ?
