Halltech Stinger
Old May 14, 2006 | 09:24 PM
whitevett's Avatar
whitevett
8th Gear
Default Halltech Stinger
I am thinking about changing the stock intake in my 2002 Vette to the Halltech Stinger. Anyone have any pros or cons?
Old May 14, 2006 | 10:25 PM
JeremyMSG's Avatar
JeremyMSG
Hello. You may want to post this over in C5 Tech or Performance Results as you are more likely to get more replies. That being said, I have had both the Stinger and the Vararam and here is how I see it. The Vararam will give you a few more ponies, especially at higher speeds. The Stinger is almost as good, especially if you do the cold air mod (do a search for this one) and is super easy to install. It just depends on what your goals are. Do some searches here on the forum, you will find more info than you will be able to read in one sitting about this. Good luck in your decision
