STS Day 1
Old May 24, 2006 | 08:30 PM
C5A4TT's Avatar
C5A4TT
Default STS Day 1
Well I think the install is pretty straightforward. Mike at Rapid did the 918s first. Then we did the wiring...straightforward but some tough manuvering...takes 2 or so hours..broke in the oil pump...pcv hookup..1/2 hour..went to the rear...air cleaners piece of cake.
Then we realized we were missing the hardware kit...one of those hiccups...called Brandon and Nyc at STS...they are overnighting the nuts/bolts so we can get rolling tomorrow...oil pump and then the turbos/piping. So far so good. Dyno Friday if we get everything done tomorrow.
Old May 24, 2006 | 09:36 PM
ProtoVette's Avatar
ProtoVette
Glad to hear its going well!!!
Keep us posted.
-Chris
Old May 25, 2006 | 12:00 AM
lewishou's Avatar
lewishou
Congrats on getting the system. Honestly I think the most time consuming part will be putting in the rocker panel piping, unless you have a z06. Anyway, good luck to you. I look forward to your dyno results.
Lewis
Old May 25, 2006 | 12:07 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Oh boy, I do not envy you (or any other STS installer) when it comes to those rocker panel tubes. If you don't already have Z06 brake ducts it might be a worthwhile extra mod to do now
I recently had to run some braided stainless hose through the rocker panels and it was a PITA to get the grinder at the right angles to remove all the extra epoxy and metal tabs preventing them from going straight through the rockers. I could only imagine without the Z06 brake ducts that job would have been hell.
and keep us posted!
Old May 25, 2006 | 09:42 AM
bernrex's Avatar
bernrex
Nice pace. You will be making some music with that vette by Friday/Sat.
Grease the pipes and hammer them in.
To STS Day 1
