How Much Boost?
Old May 25, 2006 | 06:33 PM
VICOUS's Avatar
VICOUS
Cruise-In II Veteran
Default How Much Boost?
Hello
How much boost can a Vortech SQ-trim support? I am currently running 7 psi, like all things I WANT MORE. I am planning on building a LS2 402 and I would like to run between 12-14 psi.
Old May 25, 2006 | 07:17 PM
Mike04's Avatar
Mike04
My S Trim is steady at 10psi at 6200rpm on hot days, I have even seen 13psi on a cold morning I am running a 3.6 pulley on a stock engine.
Old May 25, 2006 | 08:58 PM
7LitreC5's Avatar
7LitreC5
I think that you will need a T-Trim or larger to run that much boost on a 402.
Originally Posted by VICOUS
Hello
Old May 25, 2006 | 11:00 PM
VICOUS's Avatar
VICOUS
Your a brave sole to run that much boost on a stock motor . More power to ya, and good luck . Thanks for the info though. I know I had the S-trim on my 1996 383 LT4 running about 16 psi but it wasn't very efficent at all. I was getting ready to switch to a bigger blower when I sold the car.
To How Much Boost?
