total Timing
Old Jun 2, 2006 | 09:47 AM
MotleyDrew's Avatar
MotleyDrew
Default total Timing
Hey guys
What are you blower guys running for total timing in the car. I have HP Tuners Software and am going to the dyno next Thursday and am looking for some ranges and whatnot.
thanks
Old Jun 2, 2006 | 09:51 AM
QuickSilver2002's Avatar
QuickSilver2002
Originally Posted by MotleyDrew
Hey guys
thanks
The tools work in terms of advance (not total). Anyway, 14-22 is the range most people run. 17 is probably the norm. You just have to see what it likes.
Old Jun 2, 2006 | 10:48 AM
MotleyDrew's Avatar
MotleyDrew
Cool. I was a mustang guy so we dealt alot in total timing numbers because the factory computer added 16 degree to your base timing in those cars.
So a blower running 5.5 -6.5 lbs of boost on a stock LS6 motor with headers should be in the 14 - 18 degrees advanced range?
thanks
Old Jun 2, 2006 | 05:16 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I am at 13 degrees. Nice and safe. Anything more than 14 is pushing it IMO. You may not be getting any KR on the dyno or on a mild day but when the weather gets hot and muggy or nice and cold you would be more prone to knock.
Old Jun 2, 2006 | 06:16 PM
rplaster's Avatar
rplaster
I'm running 17 up top. I have tried 18 but when the intake air temps rise the pcm pulls a degree and i'm back to 17. Never got any knock but 17 seems to be as good as it gets without meth.
Old Jun 3, 2006 | 12:01 AM
muncie21's Avatar
muncie21
It's going to depend allot on your dynamic compression, boost and IATs. If you are running tuners, I'd start by zero'ing out the IAT advance table that way you are dealing with only one variable. Shoot for a fat AFR to start with, say low 11's. Copy the high octane table to the low, and then start easy, say 13* or so. Go up in increments of 2* until you get KR. At this point you can either back off the timing or increase the AFR to see if there are any gains to be had. Don't forget to add the IAT timing back in at the end, for safety's sake.
I recently dyno'd my ride to test out some LS6 heads (10.5:1 CR). I was able to run 18* of timing @~5PSI of boost without KR. My AFR at this point was 11.00. Keeping the same timing and increasing the AFR to 11.75 resulted in ~2* of KR, a little more torque, but no significant HP increase.
Old Jun 3, 2006 | 10:41 AM
RED99's Avatar
RED99
Good example. Your timing should be set to where it makes maximum HP. But with pump gas, you will probably experience knock before you reach that point though. So if Joe Bob is running his at 18 degrees advance, I WOULD NOT set mine to 18 just because he can run it. Too many varibles to determine what the engine can run. Fuel and compression is the biggest factor. So you will have to start low, and work your way up and monitor your readings. Good luck.
Old Jun 4, 2006 | 02:44 PM
PRAY's Avatar
PRAY
On mine as soon as it hits boost the timing is reduced to 17* then scaled back to 15* by 6,000. We have tried up to 17* but the car didn't pick up any thing. Mabey a couple lbs of tq. So we just backed it off untill it started to loose power. This held true at 6psi and 10psi. The funny thing is that the scanner only sees 14.5*. But like others have said, once the IAT table kicks in the timing takes a crap along with your power. I guess Meth is the only answer for that.
My question is, do you guys scale your timing back as boost increases? Or do you set it at a certin amount when boost hit's and leave it there? It seems to me that you could just decrease it 1* for every lb of boost from N/A and be all right.
Brett
Old Jun 4, 2006 | 11:07 PM
MotleyDrew's Avatar
MotleyDrew
thanks for all the info guys !!! I am booked thursday all day.
thanks !!!
Old Jun 4, 2006 | 11:18 PM
SpinMonster's Avatar
SpinMonster
Can anyone e-mail me a HPtuners file for a supercharged car. Just like to see what the curve looks like thanks
Detentionizover@yahoo.com
Old Jun 5, 2006 | 08:16 AM
MotleyDrew's Avatar
MotleyDrew
I will take one too ! My motor is stock with a Vortech Blower and full exhaust.
drewcameron@rogers.com
thanks
Old Jun 5, 2006 | 08:36 AM
muncie21's Avatar
muncie21
Go to this site http://www.horist.com/hptuner/
There are supercharged C5 and F-body tunes there.
To total Timing
