Dry Nitrous Install Tips
Here is a good install article from Hot Rod, I used a bit of stuff from.
Hot Rod C-5 Install
I found the hardest part was punching though the Gromment to get through the firewall.
Here is were you can tap into the power for your switches
In the passenger foot well (not sure if it is all years, mine is a 99) is that duct taped three wire combo Orange, yellow black. Orange is constant hot, Yellow is switched, Black is ground. use that for your panel.
I grounded my bottle stuff by the passenger door under the trim that covers the seat belt reel
Be sure to use a colder plug, and test your system with a wideband, My dry setup was a lean 12.5 (Bad, need under 12 for the AFR on Nitrous to be "safe"). I am changing out my nozzles and hope to wrap up my install tommorrow.
Yellow just posted pics of his dry install and it looks very Clean
Yellows Thread
Robert
Robert
^^^^^^^ definately the man when it comes to dry setups and vettes
