There are about 4 or 5 points being discussed here
FACT-Twin Screws ARE NOT more efficient than a modified roots design when in bypass mode, this IS because it compresses air between the rotors, as M T 0 has pointed out.
I just called Jim Bell on his cell phone. His question to you was.
Who in the F!UK cares about efficiency when the car is in bypass mode???? When talking about superchargers what we care about is efficiency while in BOOOOOOST..
He said if he has to start worrying about efficiency while cruising around out of boost, maybe its time for him to get out of the S/C business..
Of course he was laughing and joking when he said all of this. He did admit that there was a VERY slight temp difference, but not much in the overall scheme of things. But as soon as the S/C goes into boost the game is already won..
FACT- When the KB and Maggie are put on an identicle motor using identicle S/C's the KB is able to produce MORE boost at a lower RPM.
FACT- It takes OVER 3000 less RPM's for a KB S/C to produce the EXACT same amount of boost on a maggie.
FACT- The slower rpm's, cooler charge temps, and 20-30% LESS parasitic loss from a KB WILL/DOES produce a noticeable gain in RWHP over a comperable maggie.
These fact that I have stated are from actual side by side testing of the maggie AND KB unit. Obviously, I do not have the authority to physically post the data sheet. But I have personally reviewed the data sheets, as well as had a LONG technical conversation with Jim Bell in his office.
You would be amazed at the information this man has. His office is filled to the top with file cabinets FULL of data logs. His R&D dept has MULTIPLE maggies that have been disassembled and tested. All the way down to the chemical breakdown of the teflon coating used on the rotors of the maggie.
simple, it produces more heat in any off boost condition. Obviously, this is more of an issue with non I/C'd kits, which, as you well know, has been addressed as of late. Anytime you start building boost from a higher base temp, so then will your CDT's further increase as boost is introduced and increased. Needless to say, I was very happy to see the newer KB kits incorporate I/C technology.
Regarding initial boost and up to 10lbs or so of it, comparing "same sized" head units, using Magnuson's latest technology vs. KB's latest, results will be very close, with the edge going to magnuson in the lower rpms. so let it be written
I want to say something to all of this. I have both a corvette z06 with a KB and a 2004 lightning with a Eaton. Now i can tell you this my truck Eaton runs alot hotter then the vette's KB. The Eaton really gets heatsoak fast. One more thing a good buddy of mine has a 10's lightning that has a Whipple. He was runing low 12s with his eaton now he is in the high 10's i guess numbers mean nothing.
I've hot lapped my Radix setup 3 and 4 times in a row and run within a tenth. This was in 90+ degree weather, I saw no significant impact in performance.
