Maggie/LS2 snout problem
Old Jun 13, 2006 | 11:18 AM
BigLew's Avatar
BigLew
Default Maggie/LS2 snout problem
I have a 00 vert with a non ic maggie with ecs 8 rib system. When we went to larger MAF and LS2 tb the new snout is now rubbing the pulley. Anyone experience this/ Got a fix or suggestion??
Old Jun 13, 2006 | 11:38 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
I wish I can help, but I have not worked with the 90mm maggie inlet. Maybe some of the LPE guys have a suggestion?
Old Jun 13, 2006 | 11:48 AM
BigLew's Avatar
BigLew
Default rubbing
Creech is sending you a pic of where is it rubbing, hoping we can figure something out!!
Old Jun 13, 2006 | 02:49 PM
INTHERED's Avatar
INTHERED
Doug
Do you have any plans to offer the 90mm Magnacharger upgrade
in the near future ?
INTHERED
Old Jun 13, 2006 | 03:11 PM
BigLew's Avatar
BigLew
Default Help
ttt
Old Jun 13, 2006 | 03:13 PM
YeloZ06's Avatar
YeloZ06
I have the 90mm inlet and LS2 throttle body on my Maggie -- No rubbing problems? I thought Magnuson had a test car for that set-up. Try them?
Good Luck
Old Jun 13, 2006 | 03:32 PM
FunCool's Avatar
FunCool
I had to grind down my pulley a bit when I installed the 90mm. It just needs a bit of grinding, so it's no biggie.
And get ready for a nice power boost!
Old Jun 13, 2006 | 03:51 PM
BigLew's Avatar
BigLew
Default grinding??
FunCool, have you got the 8 rib ecs set up? If so what did you grind the pulley or the snout/gasket??
Old Jun 13, 2006 | 03:53 PM
BigLew's Avatar
BigLew
Default Yellow
Good Luck
Do you have the 8 rib ESC pulley system?? I do and it hits hard
Old Jun 13, 2006 | 03:55 PM
BigLew's Avatar
BigLew
Default Yellow
Sorry I didn't even answer your question. Maggieville acted like they didn't know me as soon as I mentioned the 8 rib!!
Old Jun 13, 2006 | 04:54 PM
YeloZ06's Avatar
YeloZ06
Biglew;
No, I do not have that set-up. I am running a 3.5 pulley and am running 5.2 pounds of boost. I want to increase it a little (6.5 lbs). What sort of power are you making with your set-up?
Old Jun 13, 2006 | 05:04 PM
BigLew's Avatar
BigLew
Default Graph in this post
Biglew;
http://forums.corvetteforum.com/show....php?t=1413674
Old Jun 13, 2006 | 05:27 PM
BigLew's Avatar
BigLew
Default Issues
Doug sent you a PM. Spoke to Chris about the pics that Jeff sent you guy. the larger snount retro for the Maggie will not work with the 8 rib system I bought from you guys. I can either try to grind down the lip on the idler pulley and see if that is enough clearence. But I'm not sure that will be enough. I really need to know where to get another idler just a little smaller. Help me out of this mess. Thanks
Old Jun 13, 2006 | 07:36 PM
RED99's Avatar
RED99
I thought you was talking about the blower drive pulley.
Got a pic?
EDIT: If it's the front lip hitting the snout, then take it to a machine shop, or a buddy with a lathe, and have them turn a bevel on the outside. I'm not even sure if you even need the lips on the idler pulley. Ask ECS if they have ran them without the lips? The only other choice is to go with a smaller dia idler pulley.
Old Jun 13, 2006 | 08:08 PM
RED99's Avatar
RED99
Here is a few pics I just took. I spaced the stock pulley up .310", which is approx. how much 2 more ribs would be using the 8 rib pulley. You can see where there is interference. It looks like it just barely touches each other. So you could either grind the bottom of the TB flange on the housing, or turn the OD of the flange down a little, or remove the lip completely on the pulley. I'm not sure why you would need a lip on that idler pulley, since the stock idlers don't have a lip. But it looks like a pretty simple fix.
Old Jun 13, 2006 | 09:42 PM
BigLew's Avatar
BigLew
Default Red
Thanks red, thats about what it looks like. Now if ECS or someone know how to buy one just a touch smaller,I'd be in business
Old Jun 13, 2006 | 10:55 PM
FunCool's Avatar
FunCool
I had the ECS 8-rib with the 8" crank pulley installed months ago.
Take the pulley to a machine shop, and have them grind the pulley down 1/4 of an inch. It's just an idler pulley. I haven't encountered any issues and I've had it now for over a month for many full throttle runs.
To Maggie/LS2 snout problem
Old Jun 14, 2006 | 07:54 AM
BigLew's Avatar
BigLew
Default Problems
ttt
Old Jun 14, 2006 | 09:53 AM
YELLOHHH's Avatar
YELLOHHH
ttt
I do not have the ECS 8 rib set up. I do want the 90mm inlet and throttle body. Please send me yours until a suitable resolution to your situation is found. PM me for shipping address.
Old Jun 14, 2006 | 10:21 AM
BigLew's Avatar
BigLew
Default Until
Sure, I'll get them in the mail today!
