Belt squeal solved
Old Jun 16, 2006 | 10:31 PM
leojnknsC5's Avatar
leojnknsC5
Default Belt squeal solved
AFter running my belt too tight, it started to squeal. I didn't know it was too tight, but it's the only explanation. When it started to squeal, a well meaning person sprayed belt dressing on it and for a minute it stopped. Then it howled. I changed the belt for a new one and problem solved.
I think, 99% sure, that when a belt is run too tight, it overheats and stretches. Belts are designed for cars that don't have accessories that require 80 hp like my D1SC. Just an alternator and water pump, etc. So its easy to overtighten. I think the rubber on teh back of the belt hardens and perhaps even starts to crystalize from the heat. Then you have a hard surface riding on a metal pulley and the result is squeal. So I threw away the belt dressing. Any other explanations?
Spoke too soon. Squeal is back.
Update: It may be that the sc pulley fits too loosely on the shaft. It comes off without having to heat it with a torch.
Old Jun 16, 2006 | 10:45 PM
xtream1's Avatar
xtream1
From: Stealth So Cal GOCC ...comming to invade your neighborhood soon
Originally Posted by leojnknsC5
AFter running my belt too tight, it started to squeal.... Any other explanations?
Yeah, you have a pulley that's not straight/aligned with the others. If it's a new style factory ATI kit I'd suspect it's the tensoiner that's out of alignment.
Old Jun 16, 2006 | 11:10 PM
leojnknsC5's Avatar
leojnknsC5
The kit was purchased in April 2005 with the thicker brackets but twin IC. The tensioner does look like it pulls toward the radiator. Is there a better tensioner?
Update: The sc pulley may not be tight enough on the shaft. It is supposed to be removed by heating the pulley with a torch, my pulley slips off without heat.
Old Jun 17, 2006 | 01:02 AM
GA Country Boy's Avatar
GA Country Boy
I tried an A&A bracket, but when I went to a D1SC from a P1SC I couldn't get it to adjust enough so I threw it out and got the new ATI Procharger bracket, did have to add some shims to get the alignment right, but it works great and easy to adjust.
Old Jun 26, 2006 | 01:23 AM
hatdragracer's Avatar
hatdragracer
Mine started squealing shortlty after starting for the first time.
Maybe I am stupid...but how do you shim to correct pully alignment.
I also noticed when I loosened the 1/2" bolt holding the tensioner arm to the bracket the noise lessened.
Old Jun 26, 2006 | 08:53 AM
KULBANANA's Avatar
KULBANANA
I had the same problem when I bolted up my Procharger. For sure the blower drive pulley was out of alignment. I shimmed the head unit forward 1/16" and its been great ever since
Old Jun 28, 2006 | 07:35 PM
hatdragracer
Finally solved mine...The belt was rubbing the lip of the tensioner, I added two very thin steel shims (roughly 1/16" total) and moved the tensioner toward the radiator....no squeaks and the belt is tight.
Can wait to burn up my clutch.
To Belt squeal solved
