It used to stay at 58 but ever since i put 60lb injectors in it stays at 54. I havn't changed anything else. Maybe it's the summer heat? I have a 98 so i have the return system. Also i hear some people talk about being boost referenced. How does this work and would it help? Oh, i have the LPE intank pump. I also have a BAP still in the box.
Does it stay at 54 at idle and WOT, if so put the BAP on and you should be back to 58-60 like before. If I knew how boost reference worked I would tell you as my mechanic did this for my setup and I see 50 at idle at 58-60 while at WOT and I also have the 97 return system and LPE pump, but have the KB BAP installed
Today I have her out for an extended period and my fp stayed a rock solid 58-60 while I was doing some extended hill country boost in South Texas and the heat was 96-98 during this time with my AC on
