fuel pump
Old Jun 28, 2006 | 01:49 AM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
Default fuel pump
It looks like my direction has changed in the 23rd hour of the planning... I was ordering my na setup tommorow and now it looks like I will be buying a used a and a p1 kit with water meth.... I will need a fuel pump.... what do you guys suggest? KB BAP with the stocker... Or a racetronix walbro unit? Will be in the mid to high 500"srwhp.
Old Jun 28, 2006 | 02:12 AM
mdhmi's Avatar
mdhmi
You should be fine with a Racetronix pump and upgraded injectors.
I ran over 500 rwhp with a ProCharger on my Y2K FRC with 42 # injectors and a Racetronix pump. That was with pump gas and no meth or Torco.
Old Jun 29, 2006 | 06:22 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Fuel System
You will be fine with a Racetronix and KB Boost a Pump for up to around 600-650 RWHP, I had the same set up and just went to the ECS set up.
Make sure you have a return line set up.............
Old Jun 29, 2006 | 07:47 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I have the 97-98 setup with the LPE pump KB BAP and I am in the mid 700 rw
To fuel pump
