Arming switch question
Old Jun 30, 2006 | 09:27 PM
RABBIDZO6's Avatar
RABBIDZO6
Cruising
Default Arming switch question
does anyone know how i can get the spray to come on in 2nd gear maybe 3rd? I have the arming switch on the gas pedal set for 3000 rpm but its for every gear. I heard something about a window swtich that will allow it to spray in a specific gear.
Old Jun 30, 2006 | 10:10 PM
Beer99C5@FastbirdPerf.com's Avatar
St. Jude Donor '08
You need a window switch that has gear lockout.
The Trick Window switch has it, its $129
Looks like this
It controls two stages and has gear lockout on both channels.
I got mine from DynoTune.
Old Jul 1, 2006 | 01:28 AM
RABBIDZO6's Avatar
RABBIDZO6
Cruising
Hey thanks alot..... I appreciate that.. Eric..
Old Jul 1, 2006 | 12:52 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Like I, you have already got a complete set-up. So, buying another window sw is wasting money. There is a cheaper way that works great. You use a micro sw on your shifter. This is about 3 bucks at radio hack. Check out out the stickies at ls1tech (nitrous section) for the wiring sticky. I have all the info there on how to hook it up and all the why/when/where's. It will allow you to start spraying in 2nd gear. Here's a pic to get you started. If you need any help let me know.
PS: Check the ls1tech n20 threads for the Z06/C5 wanted pics, would like for you to submit. Thanks
Robert
To Arming switch question
