Boost Gauge sensor Install Questions
Old Jul 6, 2006 | 10:08 AM
Villain C5's Avatar
Villain C5
Default Boost Gauge sensor Install Questions
I would greatly appreciate if someone could explain how the boost sensor reads pressure.
I'm About to install my boost gauge and to my understanding it is installed as: I run a 3/16 line from the brake booster T to the Blow off Valve, I run another T from that line to my boost sensor.
Is this a correct way to do this? I Do not understand how the sensor can get a boost reading, what does the brake booster have to do with incoming boost?
Old Jul 6, 2006 | 10:18 AM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Now you've made me curious. I'm going to have to go look at it.
Old Jul 6, 2006 | 10:19 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
That's a very large vaccuum line. The Boost gauge simply reads vaccuum. Plus it's a pretty close vaccuum line to the grommets in the drivers footwell, so its pretty easy spot.
Chris
Old Jul 6, 2006 | 11:10 AM
DanTTVette's Avatar
DanTTVette
That is the correct way to do it.
Your brake booster is hooked up to the inlet manifold.
During normal driving it sees a vacuum, which when decelerating is used to assist braking.
Under WOT your manifold (and the brake booster) is under pressure.
This is what your gauge is reading. The booster hose is used as a convenient source for boost gauges, waste gates, blow off valves and boost controllers etc...
Don't use your brakes at WOT, they won't work so well and what's the point...
Old Jul 6, 2006 | 11:35 AM
Villain C5's Avatar
Villain C5
Thank you very much I was clueless and it sounded so odd to me, but that makes sense. So am i going to have braking issues or only if my foot is on the gas and the brake at the same time?
Old Jul 6, 2006 | 11:57 AM
muncie21's Avatar
muncie21
Sheer speculation on my part, but I'm guessing there's a check valve somewhere between the brake vacuum reservoir and the vacuum/boost line
Old Jul 6, 2006 | 02:24 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
You are correct. The plastic fitting on the end of the brake booster line that connects it to the reservoir is the check valve.
As noted above, the brake booster LINE sees both boost and vacuum (it's connected to the intake manifold) but the check valve prevents the reservoir from seeing boost.
Old Jul 6, 2006 | 10:06 PM
SleepieAce's Avatar
SleepieAce
Amazing that I've had that on there for three years and never noticed where it connects. I just changed the plugs/wires today and while I was in there finally looked at it. It is plumbed into the brake booster.
Yes, I'm not that bright.
Old Jul 6, 2006 | 11:23 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Why do people answer questions they don't actaully know the answers to?
This is very wrong.
Old Jul 7, 2006 | 12:25 AM
muncie21's Avatar
muncie21
This is very wrong.
C'mon now, he's partially right....hehe
Old Jul 7, 2006 | 12:41 AM
BLOWNZO6's Avatar
BLOWNZO6
I guess you are technically right...
Old Jul 7, 2006 | 01:14 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Yeah, easy to confuse the reservoir with the hose itself, everyone always says "hook it up to the brake booster"... of course the part about using brakes at WOT is incorrect.
FWIW when your booster is not under vacuum, you will know it... pedal pressure required to actuate the brakes is significantly increased. I had an issue where my check valve popped out and I almost could not stop the car in time for the traffic light... scary. Point is, it doesn't boost up with the rest of the manifold, or you'd really, really know it.
To Boost Gauge sensor Install Questions
