Help Nos Hook-tps Wiring
Old Jul 10, 2006 | 12:19 PM
ANTHONYCORVETTE's Avatar
ANTHONYCORVETTE
Default Help Nos Hook-tps Wiring
Anybody Know On A 98c5 Is It The Blue Wire On The Throttle Boby That Is The Voltage That Hooks Into A Nos Tps Switch....thanks
Old Jul 10, 2006 | 01:35 PM
bluewire's Avatar
bluewire
Active Streak: 90 Days
Yes it is the blue wire that see's about 4.5 volts. On the tac modual if I remember correctly it is pin #1, that is where I spliced mine in for a cleaner look. You can also splice in at the T/B connector.
Old Jul 11, 2006 | 11:33 AM
ANTHONYCORVETTE
Help Me Out Where Is The Tac Module And Is It The Same Position For My Year(98). Thanks I Am Taking My Time And Making It Look Right!! Thanks Again
ONE MORE QUESTION....WHAT RPM SHOULD I SET MY WINDOW SWITCH @. ABOVE, BELOW OR @ MY ECU LIMIT...THANKS
To Help Nos Hook-tps Wiring
