Help, hardened axle problem (nitrous car)
I recently put an MTI hardened drivers side shaft in. Well got it all together and tried to re install the half shaft over the axle and c-clip. It will not go go on. The reason being, the machined area that the clip ridews in is not cut deep enough. It's not even as deep as the splines. So, it will not compress to allow the half shaft to slip over. Now my question, can I run (drag race) without the clip? I do have an e-mail into tech at MTI, but no response yet. I have a race this weekend, so any insight would be helpfull. Man I do not want to tear this all apart in my driveway again.
Then this reply,
I wouldn't run it without the clip. The clip don't hold much but it does locate the inner CV joint in the rearend.
I had exactly the same problem after I got my shaft installed. I checked to be sure the axle would slide over the shaft before I installed it in the rearend but that was before I installed the ring! After it was all together and back in the car the axle CV would not go back on over the ring, fit fine without the ring. What I did to solve the problem was grind down the OD of the ring, making a tad bit thinner. I just removed the ring and held it with my fingers and run it around on a 3.5" hand grinder with a fine disk. Only removing material from the outside, nothing from the inside or sides. I took my time and kept checking as I didn't want to remove too much of the ring. When you slide the CV on and hit the ring you can see a mark where you need to grind next. It didn't take much, less than I figured it would have taken (probably less than .030"), but it took probably 45 minutes grinding and trying. Once it started over the ring and was still a little tight I ground once more just to give a little extra clearance. Put it back on and it all went right together and popped in place.
Then my counter reply, with newest problem,
Well, I ground my clip down and started to take stuff apart. New problem, seems the cv (if that is what it's called) ***** and rubber inside the large ruber protecter seems to have come apart. Now the drive axle is about 1 1/2 inches off the hard axle and there is no more room to pull out (rotor is at max tilted outboard). What the %&$#. I hope this is understandable. Maybe, when trying to install by pushing banging against the clip that will not collapse, I weakend the *****/rubber carrier? I can't believe this jit. I don't have the correct tools that the book says to use either. Help
Robert
One more thing, on the original c-clip, I was told by MTI that they install the shaft (straight from DTE) with out the clip. Too bad they don't included this info with the product. Oh well I learned a lot.
Robert
We *ALWAYS* install the outboard snap ring on the output shafts in our differential builds here, but we use new snap rings, instead of the old, often worn-out and peened over stockers for this very reason you speak of.
One can still use the old snap rings if they wish, (most folks do without a problem) it just takes a bit of modification to correct them for proper fitment into the shaft after they have been worn a bit.
Either way is fine, its just our way is faster and easier when building as many differentials as we do.
Best Regards,
DTE
Best Regards,
DTE
Robert
The O.E. outboard snap ring groove depth for either shaft is a nominal .123" deep and our output shaft products have a groove depth that is CNC machined to .128", therefore *ANY* snap ring you used will have worked properly.
HOWEVER...
If you did not use any type of shaft locating/alignment tools to properly index either output shaft to its zero axis position in the carrier, than you *WILL* have difficulty getting either side CV joints slid onto the output shafts....
Many folks blame the snap rings or the grooves for the interference, but that is certainly *NOT* the cause of the fitment issue. When the output shafts are not properly indexed to the zero position axis within the carrier, the snap ring will get cocked in the snap ring groove causing a binding condition as someone is trying to force the CV joint onto the shaft and the CV joint axle sleeve will hit the internal ring gear carrier. If someone bangs on it hard enough, long enough...it goes on, but forcing *anything* together is *NOT* the proper way to assemble something, which often leads to other periphreal broken parts as a result.
If someone is lucky and they install the shafts to where they fall very close to the zero axis position, than they will go together easier. Conversely, if they don't, one will have all the problems you had.. We've seen this before.
Our products are machined with greater precision for a snug fit, compared to the sloppy fitting/machined stockers, therefore; they require the installer to be more prudent and meticulous when installing them for proper fitment. You should not have had to "force" or "modify" anything to make our products fit.
Do not *EVER* leave the outboard snap ring out of any differential, otherwise, you'll have effectively increased the likelihood that you'll have premature side cover axle shaft seal failure. We've seen that before also many times too from folks doing that...
One last thing... We don't know why MTI would have suggested to completely leave out the outboard snap ring or what the complete story is there, but if they are doing that with their installs, that certainly would explain why we sometimes get cores here from them that have the outer cages of the axle seals all beat up due to the interference between the inner CV joint and the axle seal in the side cover from the ommision of that snap ring....
There are *NO* un-important parts in the Getrag IRS differential..
Regards,
DTE
Robert
If the output shaft you have does not have this marking, than it is *NOT* our product... We keep very tight records of all of our outgoing product here. If it does and you have this CNC machining error, than the one you have would be the very first of it's kind to be like this since we completely took control of the manufacturing of this product in-house 2 years ago. Send it back and we'll send you another at no charge, as we would be *VERY* curious to see this shaft you're talking about..
Regards,
DTE
Now, the issue with MTI and them telling me it was a DTE, well I will address that elsewhere.
Thanks, for taking the time and having the patience to get through this. Proves that DTE is a stand up company, like I allways stated.
Robert
If need be, take a couple of pictures of it on both ends if you do decide to remove it and we'll be able to tell right away with 100% certainty if it's our's or not.
We'll do what we can to help.
Best Regards,
DTE
