a4 sts owners step inside
Old Jul 18, 2006 | 07:47 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default a4 sts owners step inside
i have been noticing when you step on it the boost gauge goes write to 5psi but wont hit the 6-6.5 mark until it shifts. is this common? i have the stock kit but with the upgraded springs. last time my tunner told me the silcone hoses were to short and they were blowing off so i got longer ones. i dont think this is the problem or its just me. because on the freeway when the car hits 100mph its showing 6-6.5 psi
Old Jul 19, 2006 | 07:41 AM
C5A4TT's Avatar
C5A4TT
Mine goes to 8psi and stays there now.
When I was running 5psi it would creep up to 6psi right before each shift.
Old Jul 19, 2006 | 08:32 AM
Carbotech Adam
Supporting Vendor
what was your fix ?. i am not sure if i have the upgraded springs. i am begining to think i dont and i am just seeing boost creep. what spring do you have ? is it the green one. what were your final # with 8 psi ?
Old Jul 19, 2006 | 09:16 AM
Jesse_Boyer's Avatar
Jesse_Boyer
STS WON'T admit there's a need for two Wastegates, but there is. That's boost creep all right...
Rick sent me a new 'over the axle' pipe with a different flange orientation that is supposed to allow the WG to direct the exhaust out in a more efficient fashion. Since i've been so busy, it won't go on till next week.
Old Jul 19, 2006 | 01:49 PM
Hammer's Avatar
Hammer
I had boost creep until I installed the 2nd wastegate.
Old Jul 19, 2006 | 03:56 PM
undertaker's Avatar
undertaker
From: ECS : WTF did you break now and HTF did you break it this time
I don't have that problem, but now I'm pretty much maxing out the turbos on a forged bottom end anyway
I think we went from 1-2 wastegates when we jumped it up from 6.5, I didn't even look when I was changing the oil yesterday
Old Jul 19, 2006 | 06:25 PM
bernrex's Avatar
bernrex
FI life starts @ 8 lbs. Don't aim too low and miss the
Old Jul 19, 2006 | 06:30 PM
bernrex's Avatar
bernrex
This may because they did most of Beta testing on the Z06. I've been told (but, never really verified) that the H-pipe in the Z is fully-open and truly functional as a crossover.
Still, whatever the case, I've only got a single WG in my '03 LS1 car ... and don't see B.C.
Old Jul 19, 2006 | 07:47 PM
undertaker's Avatar
undertaker
it gets even more exciting when you double that
Old Jul 19, 2006 | 08:58 PM
C5A4TT's Avatar
C5A4TT
Im not sure what the fix was. I know with the 5psi spring and other issues I saw some creep. With the 8psi spring it stays rock solid on 8psi. I have two X's in the exhaust and no cats...one wastegate.
Still working on the tuning so I dont have any new numbers...but the car is a completely different animal at 8psi
Old Jul 20, 2006 | 04:52 PM
bernrex's Avatar
bernrex
Yes ... life's great at super-8.
Of course for the Undertaker .... with his "stroker" motor, he can go for a sweet-16.
To a4 sts owners step inside
