SD or maf tuning?
The benefit to SD tuning (IMHO), is that it allows you to run a boost controller and change boost on the fly. The reason you can do that is due to the use of a 2-3 Bar MAP sensor. The MAP sensor can actually read boost and determine the correct amount of fuel that needs to be delivered based on the amount of boost it sees. This of course relies heavily on the quality of the SD tune that's done to the car.
Without having to go into great detail, my suggestion would be this: Set you car up however you plan to race it when you go to have it tuned (i.e. race gas, alchohol injection, open exhaust, etc). Then tell your tuner that you want the car "safely tuned in SD mode" to whatever the max boost is you want your engine to see. Then set that boost level as the highest setting on your boost controller. From there, you will be able to turn the boost down as much as you like and the tune will still keep a near perfect A/F ratio (something you can't do with MAF tuned FI cars).
With a MAF Tune, you pretty much only get one "sweet spot", and that's whatever boost level the car was originally tuned at. If you turn the boost up, you go lean, down and you go rich. The computer doesn't recognize differences in boost changes because the factory MAP sensor can't read past atmosphere. It only knows that you need x amount of fuel everytime you go WOT, and x never changes. Make sense?
Hoep that helps.
Hoep that helps.
Hoep that helps.
Rick
Rick
