n2o system and progressive controller?
My question is should I keep this system or get a dry/direct port 2 stage deal, I have considered this and think that I would need a progressive controller, I am not sure how they work though, can someone explain how they work and it this would be a better way to go, I was thinking that the dual stage would be better for the track, and I am a little wiery of the wet kit at a 150hp level, I would likely run a 75 dry and a 200 dp.
Keep in mind I am totally stock except for a Blackwing and catbacks.
On my dry system I have the smaller injectors being a 99 they are 26#
I went lean on a 75 shot, my 50 shot was fine on the dry. I started to log with EFI live and found my 50 shot dry is running the injectors at a 91% duty cycle, so I am assuming I am lean on the 75 becuase of maxing out the injectors...
The wet I have a Nitro Dave Plate kit, and ran that at 150 with no problems.
I settled on a 50 shot dry @3000 and a 125 wet @ 4000
I plan on upping the dry shot a bit and maybe using the wet to tune the lean outta the dry (have new jets on the way) when my WB is back in the car.
The two stages works good, kinda as a progressive controller, here is a graph of mine as it is now
For that 200 shot I would think you would want to have progressive control on that. The FJO progressive seems to be a favorite of those running big shots.
Here's why, IMO nitrous is for the casual speed-nut. Take a look at how you currently drive your car. A prime nitrous candidate is able to pull out of his driveway and cruise down to the end of the block, or pull away from the drivethrough window, even enter the freeway without pushing the pedal through the firewall. If you drive with this level of restraint, then in my opinion a nitrous system is for you. To me, it follows that for something used casually, there is no need to spend alot of money, hence go with a basic/functional/safe nitrous kit.
If you look at the way you currently drive, and find that if you aren't accelerating then you may as well be dead, if you race minivans away from stoplights without a second thought, or if your average gas mileage in your corvette qualifies you for the gas guzzler tax... you're going to quickly regret installing a nitrous kit. Ten refiills on my 15# bottle equates to over 600 bucks... 50 refills.. easy to do in six months for this type of driver would be more than 3,000 dollars. So just go for the fulltime boost, it's where you really need to be.
all opinion of course
A 150 dry shot is enough to roast the tires pretty easy in 1st or 2nd gear on just about any radial tire...
... that happens a lot
If you want real power go with a stout LS2 stroker... no headaches and tons of useable power... I have seen 500RWHP NA cars go up against 500RWHP FI cars and the NA car wins 99% of the time!
