Injectors...???
Old Aug 11, 2006 | 01:50 AM
2004SpiralGrey's Avatar
2004SpiralGrey
Default Injectors...???
I'm going to be running a 383 stroker LS1 with aprox. 9.5 CR and with Andy's Vortech kit 9 psi...will 42# injectors with a KB BAP be sufficient enough for fuel ???
Old Aug 11, 2006 | 02:55 AM
mdhmi's Avatar
mdhmi
Not even close.
Old Aug 11, 2006 | 07:36 AM
nitrouscharlie's Avatar
nitrouscharlie
I'm buildinng a 408 and I have the same question. I was told that 42# would be perfect if not a bit much....
Old Aug 11, 2006 | 08:20 AM
Mike04's Avatar
Mike04
You will need 60s and a new fuel system if you want to have all the power your set set up will give. My 04 with KB BAP is having problems with fuel pressure... I just ordered the ECS fuel system.
Good luck on your new set up
What pulley size are you going to run?
Old Aug 11, 2006 | 08:22 AM
mdhmi's Avatar
mdhmi
42 #'ers are good for 500-550 rwhp for the average supercharger setup. Do yourself a favor and start with Mototron 60's.
Old Aug 11, 2006 | 10:14 AM
chriswtx's Avatar
chriswtx
You need 60lb injectors and the ECS fuel system. The 2004 fuel system with a BAP runs out of fuel at around 550rwhp...
Old Aug 11, 2006 | 10:16 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Old Aug 11, 2006 | 10:17 AM
DOUG @ ECS's Avatar
DOUG @ ECS
I'll have to agree with too.
Old Aug 11, 2006 | 03:34 PM
nitrouscharlie
Didn't you just tell me on another post that 42's were perfect.?
Old Aug 11, 2006 | 04:39 PM
Chris@East Coast Supercharging's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
no, I was the one who told you that and with an N/A 408 they are perfect but this thread is talking about power adders which they would be too small. Your previous thread stated you would be running a stand alone fuel system for the nitrous.
Old Aug 11, 2006 | 07:08 PM
2004SpiralGrey
how much does is the ecs fuel system???
Old Aug 12, 2006 | 12:33 AM
chriswtx's Avatar
chriswtx
$1795....
To Injectors...???
