It begins again...
Old Aug 19, 2006 | 01:51 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default It begins again...
Day #1... Hmmm... what could be going on here?
Old Aug 19, 2006 | 02:44 AM
mdhmi's Avatar
mdhmi
Sweet. So what does the new combo consist of?
Old Aug 19, 2006 | 08:25 AM
NassauBlue98's Avatar
NassauBlue98
Not sure, but it will probably be easier this time around with your lift.
Old Aug 19, 2006 | 08:29 AM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
is this the new intake system out there with the aluminum runners?????
Old Aug 19, 2006 | 08:40 AM
99 C-5 F1C VETTE
Old Aug 19, 2006 | 11:32 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Ha Ha! Wait until you get to this stage Tony - then you know you've gone around the bend!
Old Aug 19, 2006 | 11:38 AM
Warp Factor's Avatar
Warp Factor
KB blower for 2 stages of boost.
Could also be a Turbonator install.......
Old Aug 19, 2006 | 11:40 AM
Skunkworks's Avatar
Skunkworks
That's taking weight reduction to an extreme...
Mike
Old Aug 19, 2006 | 12:38 PM
Phil97SVT's Avatar
Phil97SVT
Injectors are on the bottom or top?
Old Aug 19, 2006 | 01:59 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
TTiX for sure. This is the second car I am putting an X kit on. ECS fuel system, of course. I think I will start with just my stock motor since you and others have gone pretty far on a stocker. Later on, maybe an LS2? I want to see how good I can tune a 346 with a mild turbo cam first before moving on to a bigger forged motor.
All the typical supporting mods... aftermarket rad (probably a Dewitt's), external oil cooler, alky injection, WCCH Stage II heads (had them for a while, would love to go to AFRs when I find a good deal on them).
Would also like to make sure all the kinks are worked out for this winter since I want to drive the **** out of it at road courses. Hence me starting early and going with an easy, known build.
Old Aug 19, 2006 | 02:15 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Hey that looks alot like my car when the recovered it in LA.
To It begins again...
