During my daily warmup routine for the car ( I only drive her during the weekends so I start her up daily to keep the battery alive & sneak in a couple of minutes enjoyment during a busy day ) I noticed a new sound comng from what seems to be the supercharger belt. Chirping would be the most fitting word. Is this normal ? Note I have the 6rib setup. Is it because the belt is cold ? or the heat in my part of the world is taking its toll i.e. the belt has stiffened sp? hence the noise ?
Newbie question : WHAT ? :p My mechanical skillz are ZERO . Sorry but could you help me out a bit further.. where is the tensioner ? And how do I adjust it ?
the pulley right under the head unit main pulley is adjustible. There's a lock nut on the back side of it that needs to be loosened first, then there is a a nut on top thats connected to a threaded shaft that lets you adjust the position of the pulley to get more belt wrap around the head unit pulley. After you adjust it, retighten the lock nut...
does the sound go away after the car has warmed up? Bec i just got a P1SC kit installed by ECS and mine is making the same sound but only when it is cold. If i drive the car during the chirping the chirping becomes faster but it only lasts a few minutes.
Thanks a million buddy. I couldn't have asked for clearer instructions.
Warp Factor / MrKool,
I heard it at idling yesterday, I revved her a bit but it got louder. I think it was always there but with the hood closed , LTs and catback I don't think I could hear it well. I also suppose it does go away after a couple minutes driving.
hatdragracer,
Any idea which belt comes with the ECS kit ? Size ? Like I said in my first post it looks like the belt. Thing is I am a bit relieved now that its just noise and nothing serious.
Belt 060895 is what came with the Paxton kit. I went with a slightly longer belt to make the install easier, 060900(or K060900) Gates..Gates green stripe seems to be the best. I get mine from NAPA or Oreilys
