I have a Maggie, LT headers, GHL Bullets. I run about 6.5 psi with a 3.1 pulley at an elevation of 4500 feet. Last dyno was 440rwhp 420 rwtq. Would it be worth installing an ECS alky system? I don't plan tuning it with the methanol. I wondered if lowering the intake temps with the meth would warrant the install. Also, could I install it myself, and is there a lot of headache and maintenance with these systems? Thanks in advance!
hmm well installing a kit does take some time. Mine took about 2+ hours and this was at ECS
also the only reason i got it bec i upped the boost to 7 lbs i would not have gotten it for less then 5 lbs. I have a prochager though.
So if you got an extra 600 lying around i would buy the kit it is cheap and does help
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Originally Posted by mikes99corvette
Insurance or not insurance
If you can afford the added protection (yes, similar to insurance) then the alky is a no brainer and just makes your f/i set-up that much more reliable/durable (over the long haul)!!
