Block Questions....
Old Sep 8, 2006 | 11:35 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Block Questions....
I pulled the heads off my car, and the noticed that block is rough. I was told that I have a pre-2001 block and the block is supposed to be rough.
Now I dont think anyone would disagree that a smooth surface will seal better than a rough surface.
Should I pull the motor and smooth the block... or should I just get new gaskets and call it a day?
Old Sep 8, 2006 | 11:51 AM
nitrorocket's Avatar
nitrorocket
The surface is supposed to be rough to grip the head gasket. Different gaskets require different block and head finishes. Consult the head gasket manufacturer. I would jsut clean up the surface with a plastic scraper and solvent and assemble with new gaskets. Is this a built motor? Are you building it? For 20+ psi, the heads and block need to be surfaced.
Old Sep 8, 2006 | 12:19 PM
ICULUKN-C5's Avatar
ICULUKN-C5
The block is a built bottom end.. but I lifted the heads on the dyno when I was trying to push it to 30#.
So... when we removed the heads (heads are okay)... we broke 2 retainers, and lifter. ... I am going to o-ring the heads. but my machine shop is telling me that I have to deck the block to get that 'roughness' out of the block to get a good seal.
Please advise.
Old Sep 8, 2006 | 12:26 PM
nitrorocket
30 psi?? That is about 1500 + hp. what turbos do you have? Is this a race car??
Old Sep 8, 2006 | 12:36 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Wow... 30psi?
Old Sep 8, 2006 | 12:46 PM
ICULUKN-C5's Avatar
ICULUKN-C5
closer to 1200 on the sauce... This is a TTi X kit.
This is my weekend car.. its actually for sale in the C5 forsale section.
Old Sep 8, 2006 | 05:14 PM
BigLew's Avatar
BigLew
Default For Sale
So Glenn, what are you going to do if you sell
Old Sep 8, 2006 | 06:31 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Looking at an aston martin.
Old Sep 11, 2006 | 09:38 AM
BigLew's Avatar
BigLew
Default What?
Traitor ( my next door neighbor bought one, kept it about 6 months after waiting for 1 year to get it. Not to his liking)
To Block Questions....
