G-force transmissions
Old Sep 26, 2006 | 10:43 PM
Zrod's Avatar
Zrod
Default G-force transmissions
Does anyone with a high, power and torque, setup run a G-Force transmission? If so, what is your opinion about it? Been thinking qbout this upgrade and looking for some advice.
Zrod
Old Sep 26, 2006 | 11:26 PM
Scubanme's Avatar
Scubanme
Zrod
Check out jbsblownc5 lastest thread....he has that gearing mod to his tranny if I am not mistaken.
Old Sep 26, 2006 | 11:51 PM
Pakisho's Avatar
Pakisho
Rod, are you having problems with the current setup?
Old Sep 27, 2006 | 12:16 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Zrod
Talk to Rodney at RPM, He can set you up right. He built me a very nice tranny, using G-force 5th & 6th gears.
I believe a Full G-Force Tranny is very expensive...
JB
Old Sep 27, 2006 | 01:22 AM
#001 2001 Z06's Avatar
#001 2001 Z06
NCM, WSCC & SCC Member
At your level, I would not replace it unless it broken or going out or you are going drag racing. I think two stock mainshafts have broken at 900 rw torque.
I would have to agree with Joel. The RPM transmission is very good and I know it will hold what you are putting down.
Old Sep 27, 2006 | 08:47 AM
RoadRebel's Avatar
RoadRebel
Give RPM a call!
If your going to run on a drag radial at your power level I would certain run a 9310 mainshaft. I have seen MANY stock shafts broken in the 500/500 range let alone 700+.
Phil
Old Sep 27, 2006 | 09:43 AM
Zrod's Avatar
Zrod
Fellas, Thanks for your feed back. I'll check them out.
zrod
Old Sep 27, 2006 | 02:44 PM
R6_C5_CLS55's Avatar
R6_C5_CLS55
I bought the G-force complete T-56 with 4340 300M mainshaft, coupler and bearing upgrade, billet keys, 5th and 6th gears (I bought the 262 with SET1 overdrive)...basically everything you can get. I just ordered it a couple of weeks ago so I don't have any impressions yet. I paid $7,065 shipped. I ordered from Mark at G-Force.
My gear ratios are 2.62 1.73 1.35 1.00 0.86 0.73 and the transmission will be mated to the DTE Level 5 3.42 differential with billet right side and DTE brace. I got taller 1st and 2nd to help alleviate wheel spin in lower gears, which should also be fun for road racing. 5th and 6th should pull like crazy...up to 212 MPH with my rear tires and 6,800 RPM fuel cut.
--Sean
Old Sep 27, 2006 | 03:18 PM
YELLOHHH's Avatar
YELLOHHH
That's alot of loot!
Old Sep 27, 2006 | 04:16 PM
roythomas's Avatar
roythomas
Originally Posted by RoadRebel
Give RPM a call!
Phil
rodney is 55 & 0 for me no mercey from me
Old Sep 27, 2006 | 04:42 PM
JOHNNY P.'s Avatar
JOHNNY P.
From: IF YOUR BIG DOLLAR PROJECT DOESN'T RUN 9'S OR BETTER ....BURN IT ! SHUT YOUR MOUTH AND GRAB A LANE ! CHICAGO IL. -------- HOME OF THE FASTEST STREETCARS BARNONE !
That Rodney sure builds a a good trans .
To G-force transmissions
