MSD 8969 Digital Window Switch Wiring
I tried searching but didn't find much. There are a few on ls1tech but I'm still a bit uncertain.
I know I have to run it in 4 cyl mode.
BLACK wire is ground
RED is +12 Can I use the poitive terminal by the fuse relay box?
WHITE is tach input....I have read to connect it to a white wire, which is the tach output. Where is this wire??
Where does the YELLOW wire go
How about the GRAY wire.
I am using an Edelbrock dry system.
Thanks for your help.
http://www.ls1tech.com/forums/showpo...7&postcount=37
I'm sure some other members could give ya some better answrs , but I hope that may help.
