What size pulley do I need
Old Oct 26, 2006 | 02:04 PM
Shinyredone's Avatar
Shinyredone
Default What size pulley do I need
I need a little help and I know this is the place to get it. I have a 2001,A4, 2:73 with only one mod. a P1SC. The tuner said it had 8 lbs of boost. When I finally got around to putting a gauge on it, a year later, I only get 5 lbs. It seems to have the same power as it did the day I picked it up so I don't think its lost anything, I think it never had 8. So, my question is, on a 4.25 in. pulley can you get 8 lbs of boost out of a stock motor. If not, what pulley size will give me 2-3 more lbs. thanks for your help.
Old Oct 26, 2006 | 02:10 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
If you have a 4.5 pulley now the 4.25 should be good for around the 2 or so lbs and the 4.1 probably around 3 lbs
