Procharger Question
Old Oct 27, 2006 | 08:21 PM
kawasaki eric's Avatar
kawasaki eric
Default Procharger Question
What is the difference between the p1sc and the p1sc-1 ???
What is a good price for a used p1sc kit with the injectors and programmer ? 5000 miles on it
Thanks for any input !!!!!
Old Oct 27, 2006 | 08:45 PM
Skunkworks's Avatar
Skunkworks
Not 100% sure because not allot of info is published by Procharger. But believe it has to do with wheel design or -1 has better more efficient wheel. Original wheel had straight cut blades and was bidirectional or could spin clock and counterclockwise. Newer wheel is more up to date design with blade lean and backsweep.
Mike
Old Oct 27, 2006 | 08:52 PM
ChopperLoco's Avatar
ChopperLoco
Default Rotation!
I pretty sure a P1SC is standard rotation and a -1 is reverse rotation,also be aware-the head unit may not be "clocked" for your application-check with Procharger on both of these or it can get expensive$!
Dominic
Old Oct 27, 2006 | 09:02 PM
Skunkworks's Avatar
Skunkworks
Just checked -1 has better wheel or impeller. Look at http://www.procharger.com/models.shtml for details.
To Procharger Question
