ECS fuel pump install question
Old Oct 29, 2006 | 04:54 PM
Fastbasser's Avatar
Fastbasser
Default ECS fuel pump install question
One of the positive wires goes to the battery. The other, the one with the relay goes where? Just trying to diagnose fluctuatingfuel pressure.
Thanks in advance.
Old Oct 29, 2006 | 11:10 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Your relay should have a fat power wire going to the fuel pump... a fat power wire going to the battery... a thin ground going to, well -- any nearby ground. And a thin +12v switched lead that is attached to something like a factory fuel pump +12v lead, a boost or WOT switch, an ignition switch... whatever you so choose.
Old Oct 30, 2006 | 06:53 PM
Fastbasser's Avatar
Fastbasser
Thanks!!
To ECS fuel pump install question
