8-rib pulleys
Old Nov 3, 2006 | 10:04 AM
Stangkiller's Avatar
Stangkiller
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
Default 8-rib pulleys
I'm cheap, and doing most of my car on a budget. I now have the ECS 8 rib balancer, and an 8 rib 4" pulley for my head unit. So, i guess i need Alternator, Power steering, Tensioner, and a few idlers?
Where can i go about finding these pulleys? Or do i just need to order a tuner's kit?
Old Nov 3, 2006 | 10:06 AM
procharged_z06's Avatar
procharged_z06
Did you call Reichard racing ? im sure he can make them if he doesnt stock the already .
Old Nov 3, 2006 | 10:11 AM
Stangkiller
No I haven't really called anbody yet.
I guess my biggest question, are these 8 rib pulleys Corvette specific? Or are there other applications i can pull them from?
Old Nov 3, 2006 | 10:24 AM
procharged_z06
WWW.REICHARDRACING.COM
check it out and give him a call . he might be able to help you more then i can .
Old Nov 3, 2006 | 10:26 AM
Stangkiller
Thanks..
Any more generic information though!?
Old Nov 3, 2006 | 10:49 AM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Hopefully he wont have to wait months for them like we have, plus if your on a budget....
Old Nov 3, 2006 | 10:53 AM
Stangkiller
Thats why i was just curious if there's any cross applications or anything i might be able to search for
Old Nov 3, 2006 | 10:58 AM
LB's Avatar
LB
Andy @ A&A will have the part numbers. I believe the pullies are made buy GoodYear or Denso.
Old Nov 3, 2006 | 11:00 AM
Stangkiller
Now, that's the kind of info I was looking for.
I know the GTP guys are lathing down their stock pulleys to incorporate an 8-rib belt. Has this ever been done with success? <i'm not really tempted to try it just curious>
Old Nov 3, 2006 | 12:10 PM
LB's Avatar
LB
The cost of the idler pullies and alternator / power steering pully will be cheap. It won't be worth the costs to customize or pay to lathe and machine parts.
I would see what info you can get from Andy, and if you need any part numbers, I will see what I can get a visual on without pulling my belt off.
Old Nov 3, 2006 | 12:30 PM
Stangkiller
Thank you very much. I'll call Andy today, i just got his intake this week but i'm going to wait till i do another pretty big install....Change my A/C condensor, and new Radiator braket. and upgrade to Andy's procharger bracket as well. So i was thinking if i could do it cheap enough an 8 rib upgrade shouldn't be too hard to do at the same time.
I have the keys to a machine shop here in Orlando...cost would be free for the machining...although, i'm really pretty sure I do not want to do that on a corvette
Old Nov 3, 2006 | 03:38 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Old Nov 4, 2006 | 02:12 AM
FactoryRaceCar's Avatar
FactoryRaceCar
Old Nov 4, 2006 | 09:02 AM
Watch22's Avatar
Watch22
Have you tried ATI Part # 917346 http://www.atiperformanceproducts.co...s/damsuper.htm
Old Nov 4, 2006 | 09:54 AM
LB's Avatar
LB
I have an ATI 8 Rib Crank Balancer if you need one.
Old Nov 4, 2006 | 10:23 AM
johncbourg's Avatar
johncbourg
St. Jude Donor '09
Default On a budget
Blown on a Budget. Thats an oxymoron
Good luck, and let us know how it goes
Old Nov 4, 2006 | 05:20 PM
0EG@EnglandGreen
Supporting Tuner
He already has the ECS 8rib crank pulley. He is looking for the other pulleys (except the head unit)
To 8-rib pulleys
Old Nov 5, 2006 | 12:35 AM
moregrip's Avatar
moregrip
ATI sells all the pulleys, tensioner, alt, pwr steering
http://www.atiperformanceproducts.co.../pr/103002.htm
Old Nov 5, 2006 | 02:17 AM
Stangkiller
It's been going quite well for me so far. I've done all my own work, including my tune, with a wideband in the car. I know i have a slighty less than optimal set up, however for the $$ i have invested, i'm very pleased with my results and performance. My car is a daily driver and has been very reliable, and that was very important to me.
Pulley's are not expensive, I don't understand why i should have to pay a grand for the accessory pulleys, normally they're like 15 bucks each from a local parts store. Why are the 8 ribs so much more? Hopefully i'm able to find reasonably priced ones. I didn't get to call Andy yesterday, so i'll hit him up on Monday.
As stephen allready said, i've got an ECS 8 rib over-drive pulley installed, i'm just running a 6 rib belt on it. I am not having any belt issues currently, however when i upgrade to my A&A bracket, and 8-rib blower pulley, i figured, i might as well attempt to upgrade the rest of my system and run an 8-rib belt.
Chris
Old Nov 5, 2006 | 08:19 AM
99 C-5 F1C VETTE's Avatar
99 C-5 F1C VETTE
aint that the truth
