Krank Vent -- worth it
Of course the valves won't draw vacuum... neither will the intake manifold to be precise... what I was trying to get across is I didn't know the valves would allow that much vacuum to be created in the crankcase.What kind of funky sounds did you hear on decel?
The sound was some type of squeek. My guess was air going in the front seal, but it was impossible to track down since it would only happen on pretty heavy decel. I figured that much vacuum was not a good thing.
Bill -- no fair, you'll get to play with yours before I can play with mine
Seriously though, I am impressed -- I'm not sure what's on the inside of the Krank Vent (they say aerospace technology...) but somehow they have overcome the simple check valve designs with flappers or *****/springs. Props out to small companies like that who innovate and bring cool stuff to market.
Probably the best $100.00 mod you've spent on the car, Tony.
Ted is a great guy also.
It's the yellow car about half way down....
http://www.et-performance.com/gallery.html
You can also pick up a KV at www.kdmperformance.com
Tell Kelly that Ivan sent you.
I haven't even heard of a Krank Vent before. I always assumed that vacuum was good and boost was bad, insofar as engine longevity is concerned. Now I hear about this and I'm all confused. I already have a breather and I'm not sure if my vaccuum line from the valve cover to the throttle body is capped. I am looking to add a catch can, alky setup and high perf. fuel pump and now I hear about some check valve. Where does it all end
I guess a ported oil pump and dual roller chain is all that would be left to do before a forged motor becomes necessary.
The reason for the breather is to ensure that crankcase pressure doesn't build up. Crankcase pressure can lead to blown dipsticks, blown main seals, and other nasty issues. An unfortunate side effect of the breather is that you get little to no vacuum in the crankcase, which can lead to part throttle blowby (not as good ring seal) and some decreased performance.
With the KV, you can build crankcase vacuum and avoid crankcase pressure. Unlike a breather which just allows air to always pass, the checkvalves in the KV only allow air to pass in one direction (per valve). So the way you hook them both up allows vacuum to be built providing better ring seal, and vents crankcase pressure if it ever builds up (rather than venting all the time).
I am going to run a catch can on the KV valve between the intake manifold and the PCV nipple on the valley cover and just vent the KV valve on the valve cover to a small breather. Eliminating the breather entirely should be OK since air will only come out and it won't allow contamination into the valve cover, but I also don't want oil spurting out of the line coming from the KV unrestrained.
What about losing the vacuum after several seconds of boost (no vacuum source), when you'd want it most for ring seal?
The one thing this wouldn't totally eliminate are the fumes bled from the crankcase from getting into the cabin... which, would have been needed relocating in the first place to get eliminated.
Arnel
With a KV setup, you don't want a breather, you want the engine sealed up, so it will hold vacuum. I guess you could put a catch can between the valley cover outlet and the KV check valve to catch vapors, but how much air moves through the check valve once vacuum is created? My guess, and its only a guess, is that only minimal amounts of oil vapor can pass through the throttle body and be ingested into the motor with the KV system.
There is no perfect answer, but I think a little bit of fresh air is a good thing.
At one point I was considering getting a small wastegate for the valve cover since they are a known quantity -- a simple, high flow valve that opens at a boost pressure you define based on which spring you put in the housing. But it sounds like maybe, unless the motor is really unhealthy, the little KV does the job.
DAYUMN that Krank Vent **** works! Too good! Gonna have to throttle incoming air into crank case at idle... just like what Quick was saying. Installed my setup this morning on my 06 Silverado with a Maggie... see pics below. Took it for a test spin and during normal driving conditions under decel I would hear this belt squealing sound. Note I was also seeing 22-24 inches of vacuum on my gauge where as under same situations without this catch can Krank Vent setup I saw 17-20 inches of vacuum. As soon as I put my foot back into the throttle the sound went away. Pulled into my driveway and turned off the engine... the sound persisted for a good 3-4 seconds AFTER the engine was off. Started the engine back up, and after a few seconds this squealing sound came back. I struggled to pull my oil filler cap off and when I did it sounded like pulling the hose off of the brake booster X10! Holy Vacuum Batman!! Hope I didn't hurt my rear main seal because that is definitely where the sound was coming from. Got some more work to do here... Anyways thought you guys should know...
I'm still happy with the valve though, it opens easily and flows a ton of air. The overall system will need more than just a couple of KVs though.
