valve float with FI
Old Dec 12, 2006 | 10:11 PM
longrodlx's Avatar
longrodlx
Default valve float with FI
will i have to worry about valve float if running 7-9psi through a vortech s trim?i dont plan on upgrading blowers down the road and i dont want to make more than 500-550rwhp. i actually plan on running about 450-500rwhp. this is going to be strictly a street car with one or two passes at the track a year. are there any other problems i may run in to?
Old Dec 12, 2006 | 11:50 PM
longrodlx's Avatar
longrodlx
Old Dec 12, 2006 | 11:54 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
yes you will have to worry about that... better springs are going to be in order for an F/I motor.
VR
Old Dec 13, 2006 | 12:03 AM
longrodlx's Avatar
longrodlx
what all will i need for once i install the vortech kit? other than injectors and a tune? i also plan on throwing in a 02+Z06 cam......is this worth the effort or would i be better off just upping the boost? also can i install new valve springs without removing the heads? could i use Z06 valve springs or will i run into the same problem?
thanks
Old Dec 13, 2006 | 01:51 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Comp 918's would work fine..
Although the cam would work fine, If it were me, I wouldnt waste my time with it unless you were swapping heads.
Yes you can swap springs without removing the heads..
NO, dont waste your time with Z06 springs...
thanks
Old Dec 13, 2006 | 02:03 AM
nuke61's Avatar
nuke61
Stock Z06 springs will work fine if that's what you have right now, but if you have to change springs, there's no sense in going to Z06 springs when you can put in better aftermarket springs.
Old Dec 13, 2006 | 02:21 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Wait a minute...I just read thw WHOLE thread..
If your only looking for 500-5550 then I wouldnt bother swapping springs..
UNLESS that is you are swapping the cam as well. If not, dont bother until you start to dive further into the F/I pit..(And I do mean pit..)
Old Dec 13, 2006 | 04:47 AM
longrodlx's Avatar
longrodlx
sounds good. i guess i will keep the stock springs and cam and just throw the blower on it. not too worried about getting into the FI pit. from my last experience with my twin turbo mustang i will not let it get out of hand. i didnt even want to drive the car i had so much done to it. than i sold it once i finished it.
Old Dec 13, 2006 | 08:05 PM
Independent1's Avatar
Independent1
St. Jude Donor '08
Hate to sound like I am disagreeing with Jeff, but I would give some more thought to changing the springs. You have a 2000 FRC so you have some wear on the springs. On top of that you are going to be increasing the pressure on those springs by at least 50% (7 - 9 lbs boost) with the supercharger. It does not costs too much to change the springs and put on better retainers. The cost of valve float can be high. At a minimum if it occurs you have to change the springs anyway. At worse, you could really trash your motor. Then you are into the big $$$$ territory.
I always say better safe than sorry.
Old Dec 13, 2006 | 09:09 PM
longrodlx's Avatar
longrodlx
it actually has a brand new 2001+ engine in it with less than 15k miles on it
Old Dec 13, 2006 | 09:26 PM
TYSON1997's Avatar
TYSON1997
Doesnt matter w/ 9lbs and a surface area of roughly 3" squared on the valves that means your valve springs effectively lost 27 lbs of force, So now instead of 90ish lbs seat pressure you have 63lbs of seat pressure. Not enough!!!!! Chevy went small for better wear characteristics, and they still decided it needed 90lbs of seat pressure and they have millions of dollars into R&D. Just think about it. Couple hundred bucks on double springs could save you a couple thousand dollar motor.
Old Dec 13, 2006 | 09:38 PM
longrodlx's Avatar
longrodlx
i never heard of valve float killing a motor and would like to see some proof. i would also like to see dyno graphs showing valve float with that kind of boost from a centri. im not saying i dont believe you i just want to see it with my own eyes
Old Dec 13, 2006 | 11:09 PM
Warp Factor's Avatar
Warp Factor
LS1, stock springs, 10 lbs boost, 6500 regularly. Doesn't work for everyone. They don't seem to blow up right away if you float 'em though.
Old Dec 14, 2006 | 03:03 PM
jparr's Avatar
jparr
CI 7-8-9-10 Veteran
St. Jude Donor '08
here ya go i have valve float and im changing my spring from stock to 918 and im also changing my pushrod because bob @ epp told me they may be bent a little and that the stockers are a cheaper product
here my dyno at 5000-5500 it dips hope this helps you jay
To valve float with FI
