What is available that is larger than the 60lb injectors by Motron but are not going to cause serious problems are need extras? I was told RC made 73lb injectors, but I have not been able to find them anywhere. I am thinking of going with a dual pump setup and maybe 73lb injectors and need help. I guess now, my goal is ~700 whp. Thanks in advance.
P.S. This is via a turbo setup which, to my understanding is more demanding on the fuel system.
If anyone knows any more about the 73lb injectors, please let me know. I would love a set of slightly larger injectors rather than raising fuel pressure... but only if the injectors idle great and produce all around great results. Otherwise I'll stick with the Mototrons.
RC does sell them in Hi-impedenace-I just cheked there website. I also tried out there handy calculator-it says a 900bhp and BSFC of .60 all i need is 69lbers at 43psi?
I have a set of them. There are fine for everyday cruising. I did notice a decrease in mileage with them. About 6 less on the highway, and about 5 less in town then the 60's
I did go over the 1k RWHP mark with them. This was at 75psi. I have it set for 58 and it adds 1 pound of pressure for each pound of boost. NO METH
wow, that is pretty crazy. If I am looking to make ~700 whp which setup would you go with? Right now I have a 255 racetronix pump. I was going to also add a second external pump and lines and then have to decide which injectors. Do you think I would be ok with just my 255 pump, 60's, and maybe something like a BAP? I want to make sure I have enough fuel, but I am on a budget of some sorts. If I could get away with just adding 60's and a BAP, I would do that, but if I need to add another pump, then I am sure the price difference between the 60's and 73's is negligible.
the price difference is actually pretty large. They are near 90-100 each for 72's. I am quite sure you can make 700RWHP with 60's. the racetronix and boost a pump is a good combo, probably not enough for 700 though. Instead of adding a second pump, you may want to look at a meth kit for the difference in fuel. It will get you there with no problems, and it will be much more safe.
I will be installing a meth kit. So does that mean, the 60's, BAP, racetronix, and meth should be good to 700whp via turbo? I dont want to skimp on the fuel setup as I know that is very crucial, but I dont want to spend money unneccessarily if I dont have to. I know more is better for future upgrades, but at this point, I want to limit myself to 700 whp so I am not breaking parts left and right. Thanks again.
bump for my last question. Will 60lb Moto injectors, racetronix 255 pump, MSD or KB BAP, and a METH injection kit be sufficient for my 700whp turbo build? I will be happing with 675-700 to the wheels and want to limit myself at this level for now. Thanks in advance.
